Super charging my 2013 GT
Not quite, centrifugal superchargers don't make instant power, they have the manors on a turbo.
You'll make big power up top but it'll be a little lazy on the hit.
OP, what are your plans do you want big numbers? Or a street race king? And a senior in high school? That's a ton of car, best of luck.
A Man Just Needs Some....
But the centrifugal chargers do serve a great purpose also. Just depends on what characteristic you need/prefer. If I were to buy another cobra pre-03, it would have a Vortec or Paxton. Sometimes I would really appreciate the lag for a couple seconds. Especially in first gear. Little less torque in the lower rpm range primarily for traction. Smoking the tires at 2500rpm ain't helping anything.
Have a new 2013 GT I've been driving for a few months, it's automatic and I want to super charge it could anyone help recommend super chargers and parts to help my car handle it.... within a good price range. (I'm a senior in high school with some money but not all in the world to spend) I've looked into one roush super charger so far on American muscle
Really? When I was in high school, I too had a V8 coupe...but mine had a 2bbl carb, skinny tires, a 2.73 rear axle....and I STILL almost killed myself in that car a hundred times. No way I'd be alive if that thing went like a Coyote Mustang.
I'm not here to make a commentary on how the heck a high school kid gets his hands on a $35,000 420hp performance car (nevermind the budget for a $6000+ modificiation) but this might be a good learning moment for appreciating what you already have.
I don't mean to be "that guy" but a weekend driving school will likely help a kid get WAY more out of a car like this, improve his/her odds of surviving to the age of 19 and it will be a lot cheaper too.
Just my opinion.
It sounds like you are using this car as your DD and personally, I would grab a Vortec or Paxton or a Procharger unit. They are cheap, make great power, have cooler IAT's and because it is your DD you won't be making full boost at the lower RPM's and shredding your tires all the time. With the way a centrifugal supercharger works is it builds boost in a linear fashion, so the higher the RPM's are the more boost it makes which is ideal for DD duty. If you are really looking for some sound then check out some of the Procharger unit's as the whistle they give is very distinctive and can be heard from a bit of a ways away and the Big Red BOV in and of it's self is a bit intoxicating, the only thing I am not fond of is the placement of the air intake on them.
That is a lot of money for something that a Whipple can accomplish easily considering you probably aren't going to be building your motor.
Plus you have to find someone competent enough to tune for meth, but with tuners like Lund Racing and JPC who tune those kind of cars all the time, that shouldn't be a huge issue. Then all you have to do is keep it filled lol
That is sort of my stance on everything, if you don't have the traction to put the power to the ground then what is the use of all the power if you can't utilize it all.
I don't like methanol injection but it can and will save your motor to a certain extent. Just one more component to be concerned with. I would just trade her on a Shelby before I spent all that cash on a maxed out setup. That sounds like a $7k hit vs a few more $k on a car already at that hp. Just my opinion.
Really? When I was in high school, I too had a V8 coupe...but mine had a 2bbl carb, skinny tires, a 2.73 rear axle....and I STILL almost killed myself in that car a hundred times. No way I'd be alive if that thing went like a Coyote Mustang. I'm not here to make a commentary on how the heck a high school kid gets his hands on a $35,000 420hp performance car (nevermind the budget for a $6000+ modificiation) but this might be a good learning moment for appreciating what you already have. I don't mean to be "that guy" but a weekend driving school will likely help a kid get WAY more out of a car like this, improve his/her odds of surviving to the age of 19 and it will be a lot cheaper too. Just my opinion.
You'd be better off getting a custom Roush kit, you won't be able to run the Roush Phase 3 tune with methanol.
Shoot me a message on custom package options.
I made 680 rwhp and 577 tq AND it's AUTO which is about 20% drive train loss, with my vortect backed it down to 600 until motor is fully built. thats over 800 hp to the crank.
its not like a turbo your creating boost at idle and dumping it.
I was faced with this decision and actually put a down payment on a Vortec kit but changed my mind before paying it off and I'm glad I did. My Roush kit makes great power and the oem look you get is also great . Any of the blower kits can get you past what the stock block can handle with enough boost and supporting mods like exhaust and CAI. The TVS kits can get you well past that and the Roush kits are probably the most efficient of the PD type blowers and the VMP kits add to that with their upgraded heat exchanger. All that porting mess with the VMP kits really get you no gain over the Roush kits until your going above 15 psi so if you are staying with the stock block then you can save a few pennies and just get a roush kit.
Not following , how did you get this out of what I said. I never said anything about a 2.3 TVS making 900 hp.
I don't think you will ever make 900 with a 2.3 TVS. Maybe close to it with the Boss motor but I doubt if that even will make 800. Shelby will do it probably but why even try for 900 with a 2.3 when there are bigger blowers. I hope most of you guys grasp the concept of different size blowers. You can always go one step up on the blower and tone it down with pulleys. Making it work much less and produce more power with less boost pressure. Lot more efficiency also.
The VMP TVS has a few options though you can't get with a Roush. Like you stated an upgraded heat exchanger for one but with dual fans that really help with iat's. Also you don't have to repin anything as the kit comes with a plug and play harness. No BAP required with the Stage 1 or 2 kit as well. Just injectors needed. And the VMP stage 1 kit is $6000, the same price I believe as the Roush. All VMP kits come with an SCT and a tune from Justin. Arguably the best tuner at tuning these Roush blowers.
#40
You said the TVS will make more then the block can handle, and I was simply telling you that it's far off. The 2.3 MAY make 800, but with everything being good, the block will be safe.
