Sponsored by:
Sponsored by:
Started vortech install
Old Jun 27, 2014 | 08:03 PM
shayner's Avatar
Tear down happening and getting ready for the delivery.
Attached Thumbnails Started vortech install-image-3441638009.jpg   Started vortech install-image-3022113184.jpg   Started vortech install-image-2226495117.jpg
Old Jun 27, 2014 | 08:29 PM
MustangD's Avatar
Awesome. Have fun!
Old Jun 27, 2014 | 08:46 PM
Deerslayer's Avatar
You have any questions, feel free to ask. BTW, are you doing injectors and plugs? If so, stop what you are doing and do the plugs and injectors first (Wish someone had told me that)
Old Jun 27, 2014 | 08:49 PM
Blown CS's Avatar
The naked front end reminds me of my vmp install. Another black stang coming over to the blown side.
Old Jun 28, 2014 | 04:39 AM
shayner's Avatar
I'm waiting for the vortech like a 5 yr old on x-mas... Lol
I'm just breaking it down, getting prepped for install right now.
Seems pretty straight forward, 47lb injectors going in and the plugs I'm leaving in cause I only have 8000 k's on the motor.... I thought about gapping them to .32 but I won't be seeing much track time....not until I do the clutch and drive shaft.
I picked up a vmp fuel booster to.
The only thing I don't like about the kit is the supplied clamps the pics have shown,why wouldn't they supply t-clamps....mmmmm
Old Jun 28, 2014 | 04:43 AM
shayner's Avatar
Actually I do have a question, can I incorporate the oil separator in the pcv modification they have?
Old Jun 28, 2014 | 05:54 AM
Congrats on coming to the dark side. Reminds me so much of when I started my build. The wait was agony, the teardown fun.
I suggest still switching plugs. I should have done mine from the get go. For FI, one degree colder for full burn is essential.
As for the oil separator, I don't see why not. Again, something I should have done from the get go.
Old Jun 28, 2014 | 07:00 AM
Tron84's Avatar
I'm in the middle of my vortech install as well! I'll be sure to post if I hit any snags or anything
One thing I see right now is the lack of clearance around the head unit pulley. That large wire bundle needs to be moved a long ways, then need to figure out where to secure it to.
If anyone has a good pic of what they did that would be awesome!
Old Jun 28, 2014 | 07:33 AM
shayner's Avatar
Originally Posted by Tron84
I'm in the middle of my vortech install as well! I'll be sure to post if I hit any snags or anything One thing I see right now is the lack of clearance around the head unit pulley. That large wire bundle needs to be moved a long ways, then need to figure out where to secure it to. If anyone has a good pic of what they did that would be awesome!
Looks good, will you be using the supplied worm clams?
What other components if any are you including with the project?
Old Jun 28, 2014 | 08:15 AM
Tron84's Avatar
Originally Posted by shayner
Looks good, will you be using the supplied worm clams? What other components if any are you including with the project?
I have a built motor so I went with the oil fed JT head unit, 8 rib pulley, ID1000 injectors,
Vortech BAP. All other supporting mods were done over last winter.
I did spring for the t-bolt clamps, seems like everyone recommends them over the worm clamps
Old Jun 28, 2014 | 11:37 AM
TommyV's Avatar
I'll be ordering my V3 soon. What should I expect to pay for an install?
Old Jun 28, 2014 | 12:17 PM
Sweat and tears and about 8 hours of your own time.
Old Jun 28, 2014 | 12:54 PM
And a sore back!
Old Jun 28, 2014 | 02:27 PM
shayner's Avatar
I'm im canada and the going rate is $1700.... That's insane in my book.
Install is not that hard just time with beers...
Old Jun 30, 2014 | 08:01 AM
Deerslayer's Avatar
You can use the breather with it installed. I would suggest getting the aluminum coolant tank and I went with the T-bolt clamps and have never had a problem with hoses blowing. Install is not that bad. My son and I did it over the weekend and took our time.
Tron, instructions explain what to do with that wiring to get it out of the way. The BAP is about as easy of an install as there is. We are super pleased with our setup. Makes awesome power (more than we thought) and the car drives better than it did NA. Lund did an incredible job tuning
Old Jun 30, 2014 | 09:36 AM
Tron84's Avatar
Another few things to note:
This may just apply to the 8 rib setup since it's .28" thicker but I had to slot the upper radiator mounts and move the top of the radiator as far forward as I could to have barely enough room.
The instructions show the throttle body rotated 180 from the stock location but if you have a boss IM the motor/connector side of the throttle body actually faces downward.
Did anyone have to modify the driver side lower coolant hose? It's right in the way of the charge pipe that comes up right there
Old Jun 30, 2014 | 11:28 AM
Deerslayer's Avatar
The driver side, we had removed the lower hose and when we went back on with it, we rotated our coolant hose to get everything to have plenty of room. It took some trial and error, but we got it to fit perfect once we orientated it right. We actually tried to reverse it at first, but after studying the photo's we got it perfect.
Old Jun 30, 2014 | 11:42 AM
Tron84's Avatar
I'll have to look back through the instructions again, I didn't see any mention of the driver side hose
Old Jun 30, 2014 | 11:58 AM
Tron84's Avatar
Yup, you were right I see it now that I looked again. It is the last step of the cooling systems mod section. It just says to flip the hose around end for end, no pictures
Old Jul 1, 2014 | 11:27 AM
TommyV's Avatar
Do you have to drain the oil or do you loose any when installing?
