Sponsored by:
Sponsored by:
Safety Loop Question
Old Jun 30, 2016 | 03:38 PM
RoushRS3's Avatar
Hey everybody I've got a 12 Roush stage 3 and have the one piece Dynatec aluminum driveshaft. I'm wanting to purchase a safety loop that will work with a different driveshaft from the stock one. Does anyone have any suggestions on safety loops or has anyone installed one that is compatible?
Thanks,
Dave
Old Jun 30, 2016 | 05:04 PM
redonblackpony's Avatar
Stiffler's is the one I use and it is probably the easiest. It mounts to the transmission cross member (three bolts)
Old Jun 30, 2016 | 05:12 PM
RoushRS3's Avatar
Cool thanks man I appreciate it.
Old Jun 30, 2016 | 05:28 PM
Fairly inexpensive and you don't even have to remove the driveshaft to install
Old Jun 30, 2016 | 06:00 PM
RoushRS3's Avatar
Have you had any problems with that one vibrating. I saw some people complaining about it vibrating extremely loud under the body.
Old Jun 30, 2016 | 06:13 PM
Actually yes, mine was vibrating the whole drivetrain because it was misaligned. The shop that installed my new clutch put it back in place. Took forever to diagnose the problem. Once i found out what it was it was a easy fix though.
Old Jun 30, 2016 | 10:38 PM
5LHO's Avatar
Just push it up on the mounting bolts and tighten it, done. Let gravity work and it touches the X member and wow, noisy
Old Jul 1, 2016 | 11:02 AM
boss man's Avatar
don't forget about the blowfish bracket. It does double duty.
https://www.blowfishracing.com/drive...t-bracket.html
Old Jul 1, 2016 | 10:33 PM
RoushRS3's Avatar
So many choices
Old Jul 2, 2016 | 11:23 AM
5LHO's Avatar
I'd split the duty and go MGW and Stifflers. The Blowfish is vibey, noisy and retains the stock style shifter mechanism. That said, I'm in an auto version now, so I don't really care
Gigantor
Jul 17, 2016 12:22 PM
Dr Plastic
Jun 28, 2016 08:29 PM
TMS Editor
Jun 28, 2016 10:22 AM
