Sponsored by:
Sponsored by:
RPMs hangin between shifts
Old Oct 30, 2011 | 08:07 PM
gobraphil's Avatar
anyone elses do this at spirited rpms???
Old Oct 31, 2011 | 06:29 AM
MRGTX's Avatar
Are you referring to "power shifting" where you don't lift between gears?
If so, I would do that seldom...you're putting the drivetrain through some serious hammering doing this. I suspect that many don't even do this at the drag strip.
Old Nov 1, 2011 | 07:17 AM
gobraphil's Avatar
no.. im talking revving it up , pause, shift. Normally, the rpms would fall quickly during the pause but mine seems to fall slowly when i am in the 6k range
Old Nov 1, 2011 | 07:21 AM
JerseyGT's Avatar
sounds sketchy, i would get it looked at
AzPete's Avatar
Is this something new with your car or just different from other cars you have driven? You really don't want the rpms to drop to far between gears, even for normal driving.
Old Nov 1, 2011 | 09:38 AM
LEwis26's Avatar
Pretty sure this is normal. I remember reading somewhere that this was to help burn off extra fuel and make shifting easier.
Old Nov 1, 2011 | 10:16 AM
JerseyGT's Avatar
Guess i should have prefaced my response with this.
If the car has just started doing something strange then i would head to the dealer. I had an issue with my focus where it was hanging RPMs and it was a computer issue that they had to fix. NOT normal. That being said, if you are new to the car and its always been this way, odds are that it is fine.
Old Nov 3, 2011 | 10:30 AM
JScottGT's Avatar
This is done in the factory tune for emissions purposes. Totally normal/as intended.
Old Nov 8, 2011 | 01:31 PM
wonger's Avatar
Agree normal factory tune to ease driveline lash and smooth drivability. Try short shifting around 2500 with the pedal floored in between. You'll see the RPM's jump up between shifts.
Old Nov 9, 2011 | 06:35 AM
gobraphil's Avatar
I hear what you are saying but why doesnt it do it ALL the time and not just at higher rpms. If i let off of the gas, the rpms should go down... immediately. imo....
Wonger,
of course the rpms will hang if i short shift and floor it (if that is what you are telling me to do)
Old Nov 9, 2011 | 07:28 PM
wonger's Avatar
I'm just saying doing that will exaggerate what you are feeling. Ever notice how long it takes the car to decelerate after letting off the gas in say 4th around 45 or so? It will try to do it as smoothly as possible on the stock tune to minimize lash and make the ride more comfortable. A tune to sharpen the throttle response will change that. As for not being super consistent, well, sometimes I'll stab the throttle for a blip on downshifts and it needs to think about it, others it perks right up. It just has a little lag, and if it's acting different in between shifts, I bet it is close to the point where it is trying to smooth the transition from accelerating to decelerating and then the clutch goes in. My $.02.
Old Nov 9, 2011 | 07:33 PM
JimmyM's Avatar
Wonger,
It happens on all the shifts for me
The RPM ALWAYS jumps up and takes a while to get back down. I literally have to wait about 2 seconds before it falls to the range where I can just give it just a little gas and upshift without lurching/bucking etc. Otherwise I usually have to give it more gas or slip the clutch a little longer for smooth shift
Not to hijack, but just wanted to see if that's normal?
Gigantor
May 11, 2023 07:31 PM
Glenn
73
Apr 26, 2016 12:22 PM
K.A.I.N
Sep 25, 2015 03:27 PM
