Sponsored by:
Sponsored by:
Redline MTL fluid change
Old Nov 18, 2011 | 03:07 PM
m4a1mustang's Avatar
I changed my transmission fluid today, replacing the factory fill with Redline MTL, and wanted to share some thoughts:
- Gear engagement is smoother, especially when the transmission and fluid is cold. Cold shifting now feels similar to warm shifting with the factory stuff. It's even smoother once everything warms up.
- The transmission is quieter. I had some whine with the factory fluid that has gone away now with the MTL. I believe this has been noted by others who have used MTL.
Overall I'm quite happy with the swap. I should have done it sooner (I'm at 23,000 miles). Typically I change transmission fluid every 15-20k miles.
Tomorrow I will be changing out the differential fluid with Redline 75w-90.
Old Nov 18, 2011 | 03:57 PM
m4reapr's Avatar
good deal, same results with the mtl as you have observed
you doing 75w90 in the diff. for any specific reason?
the gear oil is spec'd as 75w140 since around 2003
ford changed it as part of a tsb to cure groaning or chatter from the trak-loc
Old Nov 18, 2011 | 05:38 PM
Not sure why I said 90. I am pretty sure I have the 140.
Just double-checked... 75w140. :tup:
I did not get any friction modifier, though, as the Redline stuff says it's already included. Think I'll be fine?
Old Nov 18, 2011 | 06:41 PM
fake's Avatar
so what did you think of that stock crap? Your eyes stop burning yet?
Old Nov 18, 2011 | 07:16 PM
Haha! The factory fill is very crappy indeed. Smells nasty, looks nasty, feels nasty... ugh!
Old Nov 19, 2011 | 08:17 AM
m4reapr's Avatar
should be fine, I used Mobile1 w/FM already in it but went ahead and added a little less than 2 oz, on the container said you can add it if desired
give it 2-300 hundred miles, if it groans on tight u-turns or slow speed backing and turning add some
Old Nov 19, 2011 | 08:41 AM
Thanks! That's what I figured I'd do.
Old Nov 19, 2011 | 09:15 AM
generalee31184's Avatar
How much did you end up putting back in tranny?
Old Nov 19, 2011 | 10:04 AM
2.7 quarts as specified by the service manual.
Old Nov 19, 2011 | 08:44 PM
So I didn't end up changing the diff fluid today. I decided I didn't want to keep the stock cover so I am going to wait. Looking now at ordering the GT500/Boss piece.
Old Nov 20, 2011 | 11:25 AM
hawkeye18's Avatar
I got largely the same results when I changed mine out. The whine isn't gone, but it's a heluva lot better. I had the QS in my trans when it came out.
Old Dec 8, 2011 | 02:29 PM
BlackMamba03's Avatar
Have you changed your diff fluid yet?
Old Dec 9, 2011 | 09:15 AM
No... I am so lazy.
Old Dec 13, 2011 | 11:11 AM
FastRedPonyCar's Avatar
Is there any trick to getting at the drain/fill bolts without a lift? Did you use a jack/stands or ramps?
Old Dec 13, 2011 | 11:16 AM
LEwis26's Avatar
I did it on jackstands without an issue. The worst part is finding a way to pump the fluid up into the trans.
Old Dec 13, 2011 | 11:36 AM
well I've got this that I'm hoping will work.
Amazon.com: Wilmar W1139 Quart/Gallon Fluid Pump: Automotive Amazon.com: Wilmar W1139 Quart/Gallon Fluid Pump: Automotive
Old Dec 13, 2011 | 02:58 PM
NJ3's Avatar
NJ3
That's the same one/style I used for my '06. It fits Royal Purple bottles perfectly but Redline bottles have a smaller opening so the pump just sits on top loosely. It still works you just have to be careful not to tip the bottle.
Old Dec 13, 2011 | 03:15 PM
ಠ_ಠ
Old Dec 13, 2011 | 09:01 PM
hawkeye18's Avatar
From the top, using 3/8" fuel line - about 4' worth. That's how I did mine. Do not have the car tilted back when you fill the trans.
Old Dec 14, 2011 | 01:01 PM
Hytek's Avatar
Those work good. I got mine from Menards for $5.
