Sponsored by:
Sponsored by:
Questions about X-pipe w/ Hi flow cats
Old Mar 1, 2012 | 10:15 AM
2012GTCS's Avatar
Not big on high flow cats as id usually say just go off road but I found a good deal on a hi flow cattled.
-Do they increase volume over the factory cats?
-Am I going to need a tune for them to not trip lights? (forcing me to get a CAI/tune combo)
-Any other known negatives about them??
Old Mar 2, 2012 | 10:25 AM
Bmeline916's Avatar
They do increase flow a good bit over stock. You will need to tune for optimal performance and or if your o2 sensors are moved.
Old Mar 3, 2012 | 03:44 AM
2012GTCS's Avatar
I've heard of them constantly tripping the engine light? Is this before a tune?
Anything special needed for moving O2 sensors? Extenders? Or Is it just swapping them over
Old Mar 3, 2012 | 06:28 AM
I'm pretty sure they are plug and play. Just higher flowing cats with the o2 in the same basic spots. I haven't seen where tune is needed when just changing to high flow down/mid pipe. Someone please correct me if I am wrong...<----- I know you would even if I didn't ask
Old Mar 3, 2012 | 06:29 AM
PS link to good deal if you don't mind sharing.
Old Mar 3, 2012 | 07:15 AM
AlsCobra's Avatar
A Man Just Needs Some....
I don't know how well the high flow cats actually work but they are doing something. All cars that came with cats are required to have cats. Unless your state or county required a tailpipe analyzer test, high flows should be good. Off road is still better for performance(not environment)lol. If you can get away with off road I would recommend going off road.
Old Mar 3, 2012 | 04:42 PM
Bmeline916's Avatar
Lights probably from before tune. You should not need a tune but will benefit alot more with a tune. Nothing special is needed just unscrew o2 sensor and screw back into new HF cats.
Old Mar 4, 2012 | 05:02 PM
2012GTCS's Avatar
The deal is someone local to me. It a magnaflow cartted X. Does 500 sound like a good deal?
Old Mar 4, 2012 | 05:27 PM
seems a little high google the part number and also check fleebay. Or is that an installed price?
Old Mar 4, 2012 | 09:33 PM
2012GTCS's Avatar
They're $800+ brand new
Sep 24, 2015 08:15 PM
