Sponsored by:
Sponsored by:
probably a stupid question...
Old Dec 11, 2013 | 10:40 PM
Divon's Avatar
Just finished up installing an Airaid CAI into my otherwise stock 12 GT. The directions had me disconnect the negative battery terminal before I started. When I was finished up, and went to reconnect the negative terminal, it sparked.
I seem to recall that a tiny spark isn't abnormal, but my HID headlamps also turned on, and I briefly smelled a faint amount of smoke. Haven't tried again, because I'm not sure if that's normal.
FYI -- the headlight switch is in the off position.
Whats going on? Don't make fun of me, LOL.
Old Dec 12, 2013 | 06:17 AM
it should be alright and yes it will spark when the connector hits the post on the battery
Old Dec 12, 2013 | 06:30 AM
Divon's Avatar
The thing I didnt understand is why the headlights turned on. I found that bizarre.
Oh and btw, I still havent tried again. It was like 1am when I tried that, and I'm at work now, lol.
Old Dec 12, 2013 | 01:52 PM
Krohn's Avatar
To be honest... I don't think it's a stupid question. I would have been stumped too... headlights turning on... hmmm....
Old Dec 12, 2013 | 02:51 PM
GrabberBlue5.0's Avatar
It's totally normal and there was no need to disconnect the battery in the first place.
Old Dec 12, 2013 | 08:05 PM
Brandon302's Avatar
Reset the PCM?
Old Dec 12, 2013 | 08:08 PM
dmhines's Avatar
I think my car also beeps horn when I reconnect battery.
Old Dec 12, 2013 | 09:04 PM
Ltngdrvr's Avatar
You will always get a little spark when reconnecting the battery, there are a number of things drawing power directly from the battery.
No idea why the headlights would come on but I wouldn't worry too much about it, probably the HID ballast retaining energy.
Old Dec 12, 2013 | 09:38 PM
Trumpetlon's Avatar
Totally normal. It is important to disconnect the negative terminal so the pcm will re-learn the new maf reading. Your idle will hunt for a bit after you start it the first time so don't get worried about that either.
Old Dec 13, 2013 | 03:55 AM
There's no need to disconnect the battery as the car will learn on it's own any changes that have been made. On the older cars yes. These cars no. I've flashed many different tune updates and have never needed to disconnect the battery.
Old Dec 13, 2013 | 11:13 PM
Divon's Avatar
Thanks for the info everyone. You'll be pleased to know my car (or me) didn't blow up lol
After I knew it was normal I put it on real quick and everything was perfect.
Ecostang
Nov 3, 2022 08:50 PM
kponypower
Jun 17, 2020 07:17 AM
K.A.I.N
13
Dec 26, 2015 01:29 PM
seaclam
Sep 25, 2015 01:29 PM
wannabe
Sep 23, 2015 05:36 AM
