Opinion on header size
I am going to be purchasing headers today and I am stuck on what size to get. I have read allot of debates about 1 -3/4 and 1 -7/8 long tube headers. I have decided to purchase Kooks as the brand just stuck on what size. In the future there is a slim chance I would maybe go FI with a 5 PSI pulley.
My mods are
91 octane Bama & Jon Lund race tunes
C&L CAI
Magnaflow street series exhaust
DSS Carbon fiber drive shaft
Circle D 3000 - 3200 convertor
4.10 gears
My mods are
C&L CAI
4.10 gears
I really don't think you will tell the difference. I got 1 7/8 and don't regret it cause they are sick as hell either way
A Man Just Needs Some....
If you are not going forced induction, 1 3/4 is fine especially long tubes. N/A and big primary long tubes will redirect some of your low end power unless you're going FI.
I say give the kooks people a call and see what they have to say.
http://ls1tech.com/forums/generation...xperience.html
I know its not your engine so its not apples to apples
Originally Posted by calgarybandit
Yes I have read that but I also read about engines that rev above 7000 the 1 - 7/8 also help higher RPM. Even with a supercharger 5PSI pulley you won't be over 600+ so 1 3/4 should work great. I sure have not found any articles or dyno results that show different unless the cub is bigger or cams etc. And I change my car like my underwear so supercharger is a slight change.
That'd be my vote as well. An 1-3/4 LT is a good compromise all the way around. It always seems to be the best header with the least amount of low end loss with the biggest gain across the mid-range and top.
And yeah that link the LS1 Tech forum pretty much coincides with all the data I've seen on engines under 400 cid unless they were intended for use really high up in the power band (5000-9000 rpm)
Hell, ARH reccomends an 1-3/4 header for my car unless its a race application.
My mods are
C&L CAI
4.10 gears
My mods are
C&L CAI
4.10 gears
Originally Posted by Glenn
but won't to big make a negative difference?
Even spotting the 5.0 around a 110% volumetric efficiency didn't require more than an 1-3/4 long tube with a 28" primary and 3" collector.
I did finally get to an 1-7/8 with a ridiculous 150% VE
BTW here is a pretty good link for estimating header size.
http://www.wallaceracing.com/header_length.php
I spoke to Kooks and the guy said the 5.0l runs efficient smaller valves he said easily could run 1 5/8 he mentioned the only reason they build 1 7/8 is people always think they need bigger. He recommended 1 3/4 would be more than enough for 8psi IF i ever went with forced induction. I called American Muscle and AHR and they said 1 3/4 also was the best fit.
