-   5.0L GT Modifications (https://themustangsource.com/forums/f800/)
-   -   New plugs on a 5.0 (https://themustangsource.com/forums/f800/new-plugs-5-0-a-499062/)
Kona Blur Aug 22, 2011 02:32 PM
Has anyone replaced the spark plugs on their 11? Any recommendations on a brand?
2012GT Aug 22, 2011 05:16 PM
Post this question in the s197 site. More technical site and modification knowledge there.
Kona Blur Aug 25, 2011 11:17 AM
I like that site alot now... Thanks
S197 GT Aug 25, 2011 11:38 AM
1 Attachment(s)
I did last weekend.
I used the Ford Racing One-Step Cooler plugs for my Whipple.
Really easy swap. 15 minutes tops.
S197 GT Aug 25, 2011 11:39 AM
*tips hat
2012GT Aug 25, 2011 01:53 PM
Originally Posted by S197 GT
*tips hat
Yeah, just found that site. Guys there aren't afraid of the ever fearful tsb and still mod their 5.0's lol.
wproctor411 Aug 25, 2011 03:26 PM
Amen on that and Beefcake has some great info.
S197 GT Aug 25, 2011 04:43 PM
My info's pretty good too! Sheesh!
Have you seen my Whipple install write-up?
Kona Blur Aug 25, 2011 10:02 PM
I did last weekend.
Think I'm gonna go this route... Thanks bud
S197 GT Aug 25, 2011 11:25 PM
No problem.
Don't run a cooler plug though unless you are getting blown, turbo'd, or running nitrous.
Just get the factory heat range.
Kona Blur Aug 27, 2011 02:37 PM
Ordered... I'll get them on Monday... I'm having some spark knock in the Austin heat and I'm hoping this takes care of that **** noise
2012GT Aug 27, 2011 04:48 PM
Someone needs to do some dyno testing with wires and plugs among other simple things; I donate my car to Steeda for anything they want to try bolt on wise (ATTN GUS!!!) ...... When i had my 2001 SS, I changed the stock plugs when it was new to NGK Tr6's and TAylor vertex 10.4 mm wires. It was worth 6- 7 more to the rear wheels depending on the run. Amsoil was worth 4-5 rwhp over the stock oil but i didn't use it. There are big gains to made by simple things. We just need to test the Coyote with some simple stuff like this and find out what makes power and what doesn't as little as it may be. it all adds up.
Kona Blur Aug 27, 2011 06:05 PM
Does FR make a new wire kit for the coyote yet? And I should be ok running plugs a heat range cooler with no boost right? New stuff for me...
zilla8 Aug 28, 2011 06:37 PM
You should not run the colder plugs unless you need to.The Ford Racing cold plugs are for use with a supercharger.You might actually lose performance running the cold plugs on a stock or bolt on N/A car.
Kona Blur Aug 28, 2011 08:08 PM
Should I get the boss plugs instead?
S197 GT Aug 28, 2011 10:47 PM
Hold on a sec...who's tune are you running? Your sig says SCT-93 Octane.
Are you running a canned SCT tune, or are you running a tune from BBR, Bama, Brenspeed, etc?
Have you been using octane booster?
Don't buy a cooler heat range plug for your current mod setup. Seriously!!
Kona Blur Aug 29, 2011 02:07 PM
I have a SCT tuner with a 93 octane tune that steeda loaded for me... Haven't swapped the plugs yet... Confused now...
S197 GT Aug 29, 2011 02:39 PM
So you have a Steeda tune, and the programmer (tuner as you call it) is an SCT device. The tune is from Steeda, you just use the SCT to load it into the vehicle.
Do not put the cooler heat range plugs in your car. They are made for a supercharged application.
When I originally replied to your thread, I mentioned my plugs and that they were for my Whipple.
I thought you might have had a question on how to read the plugs, or install questions.
I do not recommend or condone you putting those in your car.
What's making you think you have spark blow-out? Do you hear it, or are you datalogging?
Kona Blur Aug 29, 2011 03:56 PM
It sounds identical to the spark knock I had in my Durango a few years ago... I've got steeda looking into it now... Sent plugs back... PS: I'm a cartard so not sure what to do...
drewzx3 Aug 29, 2011 08:08 PM
Sounds like you need to datalog and send to steedA.
