Sponsored by:
Sponsored by:
New aeroforce interceptor with question.
Old Oct 16, 2012 | 01:39 AM
JEdwards001's Avatar
Which afr should I watch? Command afr or b1s1? What's the difference?
Old Oct 16, 2012 | 10:11 AM
Scuba-Matt's Avatar
I would think, The first one (command) is what the PCM is commanding the other is your actual reading.
Old Oct 17, 2012 | 08:58 PM
Nocturnal'14's Avatar
If you get a dyno tune they are gonna measure off your o2 sensor (B1s1) so that is what I monitor on mine.
Old Oct 17, 2012 | 11:22 PM
2011 GT's Avatar
I don't want to hijack this thread, but I have to ask: How do you like the Interceptor? Did you get the single or dual set-up? And how easy was the install?
I am considering getting the dual set-up, but would like to get some feedback first, before dropping the $$$ into it.
Thanks for any info you can share!
Old Oct 19, 2012 | 06:04 PM
I love it. It is simple plug to the obd under the dash and go. You have so many parameters to watch and you can set up a 60 second record to go back and watch instead of trying to watch while you drive, and 1/4 mile app that's fun. Plus it reads afr's with out the extra wide band set up. I would recommend it.
Old Oct 21, 2012 | 09:28 AM
It is a great tool if you know how to read it! There are a lot of options to select for display, and the majority of them I have NO CLUE what readouts I "Should" be getting! LOL
I have the single gauge right now and mine is set to B1S1 A/F up top and cycle down below head temp>IAT>Oil Temp>Coolant Temp.
houtex
05-09 Exterior Modifications
13
Apr 17, 2025 10:53 PM
defiance772
Oct 21, 2015 09:37 AM
50Cal
Sep 16, 2015 03:54 PM
