Sponsored by:
Sponsored by:
Need help with suspension
Old Mar 12, 2024 | 04:26 PM
5.0MustangNamedTyrone's Avatar
I have a 2013 gt 5.0 i bought it with eibach prokit springs as i seen them. I recently threw on 295s on the back and im hitting fender when im going over bumps. Would switching to stock springs still be hitting?
Side note
I have Some play on my rear wheel driver side. Its pokes out more then the otherside which is flush but also has aome play so im gonna replace the wheelbearing an see where it goes from there.. i dont have a pan hard i believe what would i do to make them even
Old Mar 13, 2024 | 06:21 AM
Bert's Avatar
It looks like your wheels do not have quite enough offset, so the tires are "poking" a little, and that's why they hit the fenders when the suspension travels. This can also happen if you put on tires that are too wide for the wheels; the wheels were designed with the right offset for narrower tires that fit the wheels properly. More offset effectively tucks the wheel under the car more.
If the rear only hits on one side, you can correct that with an adjustable panhard bar. Your car already has a panhard bar, that's what holds the axle under the car side-to-side, but you might need an adjustable one. From your description it sounds like the rear axle needs centering, but I'm not sure about the play that you mention.
Old Mar 13, 2024 | 03:03 PM
Siber Express's Avatar
Here are 295/35 19s on mine with 47.5 mm offset 10 inch wide wheels with the rear lowered 1.25 inches. You do have a Panhard bar from the factory, and if it is factory you can get and adjustable one to move it over to the right a little bit.
Old Mar 14, 2024 | 09:20 PM
Thanks yall
89white GT
Aug 29, 2011 10:48 PM
marc0699
Aug 24, 2011 08:01 AM
Jott
Jun 10, 2010 03:06 PM
loserpunk603
Aug 31, 2006 12:03 AM
pocket-rockets
Sep 22, 2005 09:09 PM
