Sponsored by:
Sponsored by:
Mustang IRS
Old Nov 3, 2013 | 06:40 PM
RubyTuesday2014's Avatar
Mustang IRS
I was curious has anyone installed an independent rear suspension. I see a place called Mustang IRS that sells them.
I'm hoping that Ford comes out with a replacement IRS that can be added.
Old Nov 3, 2013 | 10:04 PM
conv_stang's Avatar
The chasis is gonna be different so i doubt ford will come up with a replacement. Mounting points will be different. And will have to get proper settings for the control arms and etc. Im sure a competent chasis shop would be able to modify one to fit. But a direct bolt on prob wont happen
Old Nov 4, 2013 | 05:50 AM
Black Fire's Avatar
Put a Watt's Link on the car, it's the closest thing to IRS that this car will ever see.
Old Nov 4, 2013 | 11:52 AM
Oh I know...just wishing I could get rid of the axle hop.
Old Nov 4, 2013 | 12:54 PM
conv_stang's Avatar
Upper and lower control arms and relocation bracket
Old Nov 5, 2013 | 09:06 AM
Brandon302's Avatar
If anything I thought an IRS causes more wheel hop. What an IRS will do is stop one side of your axle dropping when the other raises, similar to a teeter-totter.
Old Nov 5, 2013 | 09:48 AM
tbone004's Avatar
I agree with Brandon302. I think there would be more issues with the IRS than the existing axle.
Every time I got in my 03 Cobra I worried about wheel hop and breaking a half shaft. I replaced several snapped half shafts in 03/04 Cobras and I even had a spare just in case.
Old Nov 5, 2013 | 11:24 AM
Well, my 2012 M3 was much more planted in the rear, and notice even small irregularities, the back end hops sideways.
Old Nov 5, 2013 | 12:01 PM
slostang's Avatar
And C5Z's are the same way....drive a cobra and tell me how you feel
Old Nov 6, 2013 | 06:42 AM
Brandon302's Avatar
That is probably due to the dampeners and not the geometry of the axle.
Old Nov 6, 2013 | 08:46 AM
conv_stang's Avatar
And all the crappy rubber bushing in all the components of the rear
Old Nov 6, 2013 | 09:39 AM
Brandon302's Avatar
OP were you looking at getting an IRS? If so why?
Old Nov 7, 2013 | 01:14 PM
TheDivaDanielle's Avatar
I've yet to have wheel hop in my Mustang, but I did get it in my IRS rear equipped GTO that i once had.
Old Nov 7, 2013 | 02:06 PM
Old Nov 7, 2013 | 03:28 PM
conv_stang's Avatar
I only get it at the drag strip with drag radials
Old Nov 7, 2013 | 04:37 PM
Roller13's Avatar
Stright Liners "drag racing" like solid rear axles and Road Racers like IRSs for good reason.
Old Nov 8, 2013 | 09:07 AM
Brandon302's Avatar
I kinda like the fun of the SRA on a road course, and the new SRA is very good.
Old Nov 8, 2013 | 09:13 AM
Brandon302's Avatar
That's not exactly the same as a true IRS since it was a bolt up piece.
Old Nov 8, 2013 | 01:30 PM
conv_stang's Avatar
The SRA in the mustang isn't it's weak link in the handling dept. it's the wheels and tires, shocks and springs. If Ford offered the option from the factory for these, the mustang could walk all over the Camaro
Old Nov 8, 2013 | 02:05 PM
The SRA in the mustang isn't it's weak link in the handling dept. It's the driver defect.
Fixed.
Exactly.
