Mustang GT non-brembo brake upgrades for auto-x/track day
I have a 2012 GT that I am piecing parts together for occasional track and autocrossing. I am a beginner and curious as to if there is a true track pad for the stock caliper? Or do I have to upgrade the brakes completely. I plan on getting ss lines, fluid, and frpp brake duct kit
Currently a Corvette Owner!
Pads, steel lines, and DOT 4 fluid to start with. Wait on the cooling duct kit, for now. When you are ready later, you may want an SVT Brembo Kit like I have, see my upgrade thread:
https://themustangsource.com/f802/brake-upgrade-515379/
Check the rules for your local group before you do anything. If you want to compete in stock class, you brake mods might be restricted. Pads are usually ok...but swapping rotors/calipers might not be.
Second, decide what your goals are...since you're just beginning, having the optimal equipment is much less consequential than the experience and practice. I promise you that your stock GT is capable of vastly more than you are at this stage....and probably capable of more than most of us are able to exploit.
My advice is to wear out what you have now and get a feel for the sport...then decide what mods your car "needs" and what mods you want to do based on your class and where you think you can be competitive.
Mike is correct. I took for granted that you've already tracked the car stock, and brakes was your first mod. Based on what I've read, tracking your car bone stock to get a 'baseline' is a smart approach. Then you can get to that set-up's limits on speed, cornering, turn-in, understeer, oversteer, braking, etc. Then you can improve the bits you want to, at your own pace. That's how I did it, and I'm glad I did.
Many moons ago, I won my stock class in a '96 Cobra that had NO modifications. I burned up the tires quick though.
Good luck, and have fun.
And by the way, if you do start upgrading pads and such, you'll have to choose between bite, noise, and dust. You'd probably find more bang for you buck in autocrossing as a novice by swapping out tires first, as that's what helps in the stopping as well. Even then, I think the same suggestions apply - get practice on the stock equipment first.
Originally Posted by Tony Alonso
Especially for autocross, as generally the top speeds aren't as high as going on to a track. It's better to concentrate on the form, smooth driving, finding the apex of corners, etc.
whysoserious
05-09 Interior and Audio Mods
10/27/23 06:42 PM
