Sponsored by:
Sponsored by:
Lower Fog Lights, Brightness Question
Old May 3, 2016 | 08:00 AM
tourer's Avatar
I had the Lower Fog Lights added/installed to my 2013 GT Premium by my ford dealer (Grappone Ford, NH) they ended up adding them to the same circuit/wire that powers the Upper Fog lights, so when I pull the switch both upper and lower fog lights come on. The lowers aren't very bright. I wonder if it's a lack of power/amperage to run both lights on the same circuit?
Old May 3, 2016 | 10:38 AM
DJ2014's Avatar
I don't think that's the problem. I have the Pony Package with the lower foglamps and mine aren't very bright either. I replaced the bulbs with brighter ones and that helped some. I don't remember the brand of the bulbs either.
Old May 3, 2016 | 12:24 PM
tourer's Avatar
Thanks for the input.
Old May 3, 2016 | 01:03 PM
Joeywhat's Avatar
Remember, they're fog lights not headlights. They are supposed to illuminate Lane markers when visibility is poor, not light the road far ahead of you.
The GT grille lights are more driving lights and are more suited to providing additional light while driving, especially when aimed a little higher.
Old May 3, 2016 | 09:13 PM
5LHO's Avatar
they are projectors so they won't be bright unless you look right into them and the factory 35 watt H11 bulbs aren't going to do much either. Doing it the way they did will likely lead to blown fuses as that circuit will be overloaded using halogens. I'd replace them with bright LEDs like these:
http://www.ebay.com/itm/371476542813
They ain't ever going to be super potent but, they fill in the low beam a little bit.
Old May 4, 2016 | 06:31 AM
tourer's Avatar
Just ordered a pair on Ebay, Thank you.
Old May 4, 2016 | 06:44 AM
tourer's Avatar
5LHO, The lights you suggested, They are for the lights in the Grill or the Lower Fog Lights?
WhiteBird00's Avatar
Bear in mind that running more than four lights on the front (four fogs plus headlights) is illegal.
Old May 4, 2016 | 06:48 AM
tourer's Avatar
I don't think so in Maine, where I am but I will check with my local PD, Thanks for the input though, it's appreciated.
Old May 4, 2016 | 06:57 AM
stupidgenius36's Avatar
Just Plain Rude!
If you want them to function as actual fogs, then that's probably fine. If you wanna put out some real light to supplement the headlights, then maybe look into getting something to fit like this: https://www.theretrofitsource.com/co...l#.Vynw2p9OnqA
Old May 4, 2016 | 06:59 AM
Unfortunately, Maine is included...
Title 29-A, Paragraph 1909-A:
1. Fog lights. A motor vehicle may be equipped with 2 fog lights upon the front of the motor vehicle that emit amber or white light as long as the rays from the lights do not shine more than 2 feet above the road at a distance of 30 feet. A fog light mounted higher than the center of the main headlights may not be illuminated while a motor vehicle is being operated on a public way.
So, while they don't seem to limit the total lights like most other states, they specifically limit the number of fog lights. You might be able to claim that the grille lights are "auxiliary" lights rather than fog lights but that's not what Ford's documentation calls them and who needs the hassle?
Old May 4, 2016 | 07:24 AM
tbone004's Avatar
If you haven't seen this thread, take a look. These are what I put on mine and they are nice, pricey but nice and brighter than stock.
https://themustangsource.com/forums/...review-534495/
Old May 4, 2016 | 07:26 AM
tourer's Avatar
My local PD called the grill mounted lights "Driving Lights" The Chief of police just answered my e-mail about this and he said he couldn't find anything stating it's illegal to run 2 headlights, 2 driving lights and 2 fog lights, as long as their positioned right.
Old May 4, 2016 | 07:30 AM
tourer's Avatar
Link doesn't work.
Old May 4, 2016 | 08:10 AM
Joeywhat's Avatar
Why not just use the fog lights as for lights, and the driving lights as driving lights? I can assure you when properly aimed, both will do their job well and having both on will be redundant. When you actually need fogs the driving lights will need to be off, and the fogs won't add any useful light the driving lights don't already throw out.
Plus it looks stupid with 6 lights on.
Old May 4, 2016 | 08:20 AM
tbone004's Avatar
Link doesn't work.
Link worked here, try searching on "Diode Dynamics XML2 LED".
Old May 4, 2016 | 08:47 AM
5LHO's Avatar
The little CS fogs are so low and because they are projectors, they won't blind anyone so, adding them in, like I did, really is low risk of attracting the attention of PC Plod. I believe you can't have too much headlight, it's a primary safety system. I used 60w equivalent LED Samsung bulbs to allow me to tap into the power for the grille fogs without blowing the fuse like using the halogen H11s would have done.
That and the fact the entire conversion was about 128 bucks on ebay and made the front end look better than those ugly blanking plates, made it worthwhile.
Old May 4, 2016 | 08:50 AM
tourer's Avatar
I don't have a choice, the dealer hooked the driving lights and fog lights on the same switch.
Old May 4, 2016 | 09:09 AM
Joeywhat's Avatar
It's pretty simple to wire them individually if you'd like to. I have my grille lights wired to an independent switch on the center console.
Old May 12, 2016 | 07:59 AM
Coyote5-0's Avatar
Got any pictures? Im wondering what this looks like with and without the lights on
