Sponsored by:
Sponsored by:
Installed cai now car jumpy
Old May 13, 2011 | 09:42 AM
Phantomx2's Avatar
I just installed the steeda cold air intake 2 days ago on my 2011 gt manual n yesterday n today I feel like the car is a little jumpy while I'm getting the rpms up to shift into the next gear. It's slight not extremely noticeable but I think I feel it. Does anyone know what the problem could be? All I can think of right now is clamps r not tight enough, it's my imagination, maybe the cai requires a tune, or the little extra power wants to make the car go but I'm not home to check any of those. Does n e one have any other ideas?
Old May 13, 2011 | 09:57 AM
klisetron's Avatar
Yes, the tune is REQUIRED. They even say it could damage your engine if you don't get it tuned. They have to tune it because of different MAF tube size(speculation). Stop driving it if you have no tune on.
Old May 13, 2011 | 10:11 AM
Phantomx2's Avatar
Awesome thank you. I bought it with the tuner but I was going to wait to tune it because I wanted to make sure the check engine light didn't come on from the cai before I tuned it.
Old May 13, 2011 | 10:18 AM
m4a1mustang's Avatar
Tune... NOW!
Old May 13, 2011 | 10:51 AM
Phantomx2's Avatar
Will do. Thanks for advice. I will reply after it's installed
Old May 13, 2011 | 10:55 AM
codeman94's Avatar
you're running WAY too lean. Tune ASAP to prevent engine Damage. Your CAI should have come with a warning message telling you not to attempt to use it without a tune...or at least whoever you bought it from should have told you that....
Old May 13, 2011 | 11:07 AM
klisetron's Avatar
Yea it does, but you would have to assume they read the instructions carfully to see it. Not saying you did or didn't, but I did notice the warning could have been a bit more "noticeable".
Old May 13, 2011 | 11:48 AM
y2kcbr's Avatar
You didnt get any engine codes? The 1401 or anything? I ran lean on my other mustang and had engine codes after 50 miles or so. drove me nuts until I got it tuned (funny thing, it was pre-tuned from BBK).
Old May 13, 2011 | 12:02 PM
2011_STANG_GT's Avatar
Old May 13, 2011 | 12:03 PM
Phantomx2's Avatar
I ordered the combo pack and never seen a required tune notice. I read all directions for the intake install and nothing. Once someone on here said the tune was required I checked american muscle cold air only and that is where I saw it. I must not have driven far or long enough to get any engine codes cuz I had no check engine light. I just tuned the car and I noticed the jumpyness did go away and I do have added power. I love it.
Old May 13, 2011 | 12:14 PM
codeman94's Avatar
glad to hear! Enjoy!
Old May 14, 2011 | 05:24 PM
montreal ponies's Avatar
I do remenber seeing a WARNING label that came with the Steeda CAI about not to run the CAI without a tune.
Old May 14, 2011 | 06:59 PM
revenge's Avatar
Well some CAI have inserts and do not require a tune. But if you install them and do not put it in you could have a problem.
Old May 14, 2011 | 08:42 PM
klisetron's Avatar
The steeda cai does not have inserts, I think the only one I've seen was jlt or c&l (not sure exactly) that has the insert. I remember seeing the warning too for steedas. They should make it more visible on the instructions, like the whole first page.
Old May 14, 2011 | 10:01 PM
SoCalCobra311's Avatar
My install instructions said requires a tune all over the place. even the last step said you are done a tune is now required. Same steeda unit
Old May 16, 2011 | 04:08 PM
Phantomx2's Avatar
Well the car is tuned I didnt run it a lot without the tune so I feel the car is still good. But the comment I made about the car being jumpy I now only notice when the car is still cold. I used to wait for the rpms to drop below one then drive now if the temp gauge is still on C. If I do that now I will feel a slight jump from the car while the rpms are increasing to the next shift. But once the car is warmed up it (the needle moves closer to the middle) it all goes away.
Old May 17, 2011 | 08:22 AM
MustangGTPilot's Avatar
Airaid come with an insert for non tuned motors, reduces the internal diameter of the CAI by 1/2 inch or so around the MAS.
I returned the car to stock for a dealer visit and got distracted and forgot to put in the insert, well I couldn't even get it out of the garage until I put the insert in!!
Old May 17, 2011 | 10:27 AM
klisetron's Avatar
So airaid for sure, and I thought there was another one being sold that had that feature/option?
Old May 17, 2011 | 12:59 PM
RedCandy5.0's Avatar
You should use your insert for the Airaid tuned or not unless you are heavily modified. Without it you will get a lot of noise gets in the Maf signal.
Airaid said this themselves.
The MVT is there so the kit has the proper calibration and proper air fuel ratios. Removing the MVT will not result in a performance benefit as it is not a restriction in the system, but there for calibration.
The only time you would need to remove the MVT is if you were going very radical with modifications ie Heads, Camshaft, Forced induction, basically modifications that would constitute a complete custom tune.
If you are just going with basic bolt-ons, such as long tube headers, cat-back, or a hand held tuner I would advise leaving it in as that will result in the best performance and drive ability.
Thanks,
David
Old May 17, 2011 | 06:10 PM
codeman94's Avatar
Hey phantom, make sure the throttle body is clean. Sometimes when you install a cai it's an opportunity for some oil to build up behind the butterfly.
Ecoboost
Jul 25, 2015 06:32 PM
valanahara
Jul 22, 2015 05:13 PM
stewarts359
Jul 21, 2015 03:39 PM
Kgilly
Jul 9, 2015 01:47 PM
