Sponsored by:
Sponsored by:
Idle change from oil seperator install
Old Feb 3, 2015 | 09:32 PM
SONICBOOST's Avatar
Has anyone noticed an idle change from installing an oil seperator? Not sure if my car has done this before the oil seperator and I'm just paranoid but since the oil seperator it's seems to sometimes slightly drop to about 600-650 rpm from 750 during idle. Is that normal and I'm just being paranoid? I'm not to familiar with the crimp clamps that came with the steeda kit so I may get the screw clamps to make sure everything is tight.
Old Feb 3, 2015 | 10:03 PM
SplitSecond's Avatar
An oil separator should not change the idle. I would make sure the connections are secure. Its possible that you could have a vacuum leak as a result of a leak from a lose connection, though vacuum leaks usually result in a higher idle speed. Though a vacuum leak could also cause a stuble.
Old Feb 3, 2015 | 10:21 PM
SONICBOOST's Avatar
Thanks, I'm going to install some screw clamps tmrw and make sure everything else is tight.
Old Feb 4, 2015 | 03:36 PM
'14Oreo5.0's Avatar
Does your idle change occur only after cold start or anytime you come to idle after driving around?
Old Feb 4, 2015 | 04:21 PM
SONICBOOST's Avatar
After it's warm, it doesn't do it all the time but sometimes it will dip maybe 50-100 below 750 rpm.
Old Feb 4, 2015 | 04:24 PM
SONICBOOST's Avatar
I also took off the compression clamps that came with the kit because I couldn't get those really tight so unsealed them for screw clamps to make sure all the fittings are really tight. It's possible my car has done this before the oil seperator install and I just didn't notice. Does everyone else's idle stay exactly constant?
Old Feb 4, 2015 | 09:45 PM
Varilux's Avatar
My idle definitely dips from time to time (especially when it is hot outside). In fact, occasionally when I depress the clutch (in bumper to bumper traffic), the idle will dip far enough to cause the car to stall.
I don't have an oil separator installed. I've also noticed the car will idle about 50-100rpms lower than normal from time to time.
Old Feb 4, 2015 | 09:49 PM
SONICBOOST's Avatar
Originally Posted by Varilux
My idle definitely dips from time to time (especially when it is hot outside). In fact, occasionally when I depress the clutch (in bumper to bumper traffic), the idle will dip far enough to cause the car to stall. I don't have an oil separator installed. I've also noticed the car will idle about 50-100rpms lower than normal from time to time.
Thanks for the response. This is basically what I have noticed. I guess i was looking for small things after the install since I had to cut into the lines. I'm guessing this is normal behavior for the 5.0.
Old Feb 4, 2015 | 09:54 PM
Jazzman442's Avatar
Put the Stock hose line back on and see if it still is doing the same thing.
Old Feb 5, 2015 | 11:11 AM
SONICBOOST's Avatar
Great idea but I wasn't too happy with the first cuts and placement I made on the hose that was provided so I re cut the stock hose for better fitment of the can. In wish steeda provided the hose pre cut because there is like zero room to mess up with the 2 1/2 cut out of the hose being as the hose barely bends. I went to the dealership to order a stock hose, they said it should be in by noon so I will know then!
Old Feb 5, 2015 | 11:23 AM
Jazzman442's Avatar
I told Steeda the same thing. I think they would sell a lot more if they did. Lucky for us the factory hose is cheap. I did not like the way it looked so I made custom hoses. Now it looks factory.
Old Feb 5, 2015 | 02:52 PM
SONICBOOST's Avatar
I guess I was being paranoid because I put the stock hose back on and it still does an occasional 50-100 rpm drop. I'm glad because I really want to keep this seperator on my car.
Old Feb 5, 2015 | 03:12 PM
SONICBOOST's Avatar
That looks really good.
Old Feb 5, 2015 | 03:13 PM
SONICBOOST's Avatar
I also already noticed a little bit of oil collected in the can, good stuff!
Old Feb 5, 2015 | 04:17 PM
Jazzman442's Avatar
Thankx it took a while to bend the pipes to get it just right. I had to find a store to get the 90 degree elbows. I am still trying to find aluminum ones.
When does the idel change?
Old Feb 5, 2015 | 04:27 PM
SONICBOOST's Avatar
Thankx it took a while to bend the pipes to get it just right. I had to find a store to get the 90 degree elbows. I am still trying to find aluminum ones. When does the idel change?
After sitting for like 10 seconds the idle will dip maybe 50-100 here and there.
Old Feb 5, 2015 | 04:30 PM
SONICBOOST's Avatar
After the car is warmed up a bit.
Old Feb 5, 2015 | 07:38 PM
Jazzman442's Avatar
I'll Check mine tomorrow and let you know.
Old Feb 5, 2015 | 08:01 PM
SONICBOOST's Avatar
Sounds good
Old Mar 3, 2015 | 02:45 PM
Jazzman442's Avatar
Ok I know I am late. But Guess what. After letting it site I looked at it and mine does the same thing. it goes about 50 to 100 rpm. Not a big deal I think most cars do. Never noticed till you said something.
