I have never used the Livewire before the handheld has a KAM reset function built into one of the options menus. I noticed it after a software update a while baci. If you do not see the function, you can disconnect the battery and turn on the headlights for 20 minutes. Turn the lights off then reconnect the battery to do a KAM reset.
Originally Posted by MorePowerTuning
(Post 6573134)
The Livewire TS doesn't always reset KAM when it installs a new tune. First thing I would suggest is simply returning to stock and re-installing the exact same tune.
This has happened to me more than once and that usually cures it. Now that being said there are certain tune changes that will cause this as well. Hope this helps. -Mike |
Good to hear. Let us know what happens.
Originally Posted by sloppymax
(Post 6573155)
(Post 6574060)
Originally Posted by BadHabit2Break
(Post 6574808)
and leave the ket in the ON position during the 20 minutes.
Taking it back to the shop in the a.m. to show them the problem. |
UPDATE: So after taking CAI apart, cleaning MAF sensor, cleaning throttle body, re-assembling CAI, and checking all connections, disconnecting/re-connecting battery, etc., etc., the idle surge is still occurring. This is after a second visit to the shop. They were able to reduce the surging... to the point that at least it doesn't feel like it's about to die out on me while at a complete stop. It looked like the shop corrected it, but I noticed that it was still occurring awhile later. It seems that if I turn on the A/C, it idles more steady.
Next step... acquire Windows-based laptop... install SCT software... data-log with SCT Livewire TS and laptop... begin remote tuning with another tuner. Any suggestions? |
Steeda email 93 tune!
J tunne, I have the same issue. Same idle video also, I hate it I am down to replacing the spark plugs and tps because I have done everything after that I am taking it in.
Originally Posted by Darkknight02007
(Post 6610654)
I just installed the airraid CAI and no tune... I was thinking about doing a tune in the future... But all these issues I am hearing (besides the op) is scaring me. I am tempted just to leave it stock :(
Had Steeda 93 tune and now a custom tune since I got rid of my Boss intake and added a Lethal off road h-pipe. Have had a tune for over 15,000 miles. Have had tune with stock CAI, Steeda CAI with the Boss intake and now back to stock intake and JLT CAI with the off road pipe. As long as you get a tune from a reputable tuner you will be fine. There are some rare cases of issues, but a good tuner will be able to get that fixed.
Originally Posted by conv_stang
(Post 6610788)
Originally Posted by FromZto5
(Post 6610802)
Issue is, I'm farrrrrrrr away from a reputable tuner. So if I do tune, will have to be a preordered tune from bama, steeda, or vmp. Am just still worried about "not running smooth" issues... Like idle issues, surge issues, hesitation, etc. IMO, not worth it if chance of those issues |
(Post 6610802)
(Post 6610922)
You get a tune from Brookspeed or VMP they are as smooth as butter. No issues at all. |
When we send out a tune it is usually spot on ... Gus is great at making these tunes work the first time around. Sometimes, these cars react differently ... that is when we need to do some adjustments or data log to make sure it is spot on. There are minor hick-ups that occur but nothing that will cause your engine to fail.
OP ... send me your email address and we will see if Gus can see what is taking place. Who is your original tuner? If your looking for a safe & powerful tune ... then you should look no further than Steeda. We have had a lot of success with our tunes - 0 issues to date when it comes to Warranty claims and engine failures. I would love to help anyone out or answer any additional questions at tim@steeda.com. Best Regards, TJ |
1 Attachment(s)
Originally Posted by tj@steeda
(Post 6610944)
OP ... send me your email address and we will see if Gus can see what is taking place. Who is your original tuner? If your looking for a safe & powerful tune ... then you should look no further than Steeda. We have had a lot of success with our tunes - 0 issues to date when it comes to Warranty claims and engine failures. I would love to help anyone out or answer any additional questions at tim@steeda.com. Best Regards, TJ Attachment 136704 |
My new-to-me 05 is doing it too, dealer said it's air intake to the throttle body or something? (a bit mechanically challenged) and probably due to sitting in the garage for the last 2 years. She is bone stock...original tires!
1. ONLY in park, and ONLY with the AC on, it will idle up/down, typically doesn't die, but acts like it. Acts normal otherwise. 2. More evidence the TB is acting up is the gas pedal, there is a hesitation when you initially hit the gas, only for a second, and only the 1st inch or so of pedal, then it will hit and go...makes putting around in a parking lot interesting. Gonna get the throttle body cleaned/or replaced and see if it fixes....Anybody want to recommend a after market throttle body? |
