Exhaust banging on cold starts
Had a catback installed and noticing now on cold starts I get a bad banging/tapping. Metal on metal for about a minute then it stops. However, when driving, it rides most bumps smooth with no abnormal sounds/banging. But certain few bumps I'll get a noise.
Just wondering if anyone experienced the same. Any ideas what part of the exhaust is the culprit? I was assuming the OTA pipes?
The car is lowered on Steeda Utralites -1.25"F, -1.5"R.
Exhaust is Borla S-types, Borla over axle pipes, Bassani X pipe, stock cats/headers.
I figurrd out where it's coming from. Right where the OTA pipes and AB clamp together it's completely resting on that black bar. Not even sure what that bar is, but its right under the panhard bar. Passenger side has plenty of clearance and the drivers side usually winds up with less but this is completely touching.
Any ideas how to get that to be higher up? Or will I need to loosen everything and readjust? Thanks!
Same thing happening on mine but its related to a ****ty weld job when the previous owner stubbed the resonators (BACK) in.... Should've looked at the car better when I test drove it. Hahaha oh well time for a cat back!
Btw, did you read my thread on my borla a types cat back? I couldn't be happier. I have tons of vids there too
Hey Burton, haven't seen your thread yet. The Bassani X is perfect, its the pipes laying on the panhard brace. I will most likely get it fixed one of the next 3 days when I'm off. It didn't make noise when I first got it, so hopefully it doesn't get fixed and shift again.
Need a little more advice. Well we determined its hitting the metal below the panhard bar...the pan hard brace.
Now when we adjusted it to where it doesnt hit, the left exhaust tip is tilted in and point down. Very ugly. When i center it just by pulling on the tip u can hear it make contact.
Any advice on how to get the muffler tip straight and the pipe to not hit?!?! It seems impossible! Has anyone had this issue? Thanks!
