Estimate for gear install
Make sure you do some research first as to who will do the best job for the price. Don't use a shop solely based on price. There is a lot that can be screwed up with a bad install. I agree with everyone else here install can range from as little as $300 to as much as $500. It should not take more than 3 hours labor.
I got an estimate from Ford racing at a Lincoln/Ford dealership for 800.00. They said this work would not void my 2012 warranty. Obviously I would get that in writing, but my warranty being covered and the work being done by Ford racing might be worth the extra money. Changing my 3.31 to3.73.
Originally Posted by 2k7gtcs
$350 labor. I supplied all parts, gasket material, oil, and friction modifier.
It took the guy about 4 hours on a lift.
The key is to get someone with experience installing gears in a Ford 8.8" rear end. The more they've done the better. Subarus and Nissans are not Fords. Be specific. Best place to look is the dealer or a shop that specializes in Mustangs even Fox bodies as they are 8.8" rears (the V8s are) or Ford F150s.
robjh22
Sep 8, 2015 12:31 PM
