Dyno numbers are here!!
Originally Posted by AlsCobra
The guys from your first post dyno sheet.
Originally Posted by Bmeline916
Oh! Thunder racing yeah I use them for their dyno cuz its a mustang dyno
definitely not getting any work done their! Why what storys have u heard???
Lt's and x pipe were one of my fav mods. You will def feel it and hear it.......get ready to hear it lol. As far as the boss intake.....it is what it is. Everyday driving you won't see anything unless your up in the 6000 rpm n up range and if you are you def see the horsepower. Good luck with your build.
TPS just recently teamed up with thunder. Thunder was strictly GM speed shop. I know a few of the guys from TPS so I won't go into detail. But they won't touch my car. Cody is one of the best around though. They only negative I've heard about Cody is about $$$. But you get what you pay for.
I put down over 20 more whp than most stangs with just cai and tune may have a lil torq lose but it will come back up with the LT's and o/r x pipe and CDT. And running back to back with someone don't mean crap if he is a better driver than you or the other way around. On a even field a person with more power to the ground has a potential to run better times! Now granted suspension mods, weight reduction mods, tires, track prep, and temp. Play roles in this also. But like I said on a even field more power to the ground = better times on the track and that is a fact!
And the reason I said race a friend is because roll racing takes out all the suspension,track prep, traction blah blah blah issues. Find someone with a similar car, roll race them before and after the boss intake. Same driver same car same road same everything, only change is your intake and tune. Let me know how it works out. Until you do a fair comparison like that, or on a dyno, or a 1/4 mile time, you're talking out of your *** saying the boss intake is worth the money. If you don't care about performance and want it to look good then yeah its worth the money, but I am talking about real world gains.
No offense taken just stating facts
the Boss mani is worth the money just for the fact that the stock mani faceplants at about 6400 to 6600 where as the boss keeps pulling all the way to 7800! Now I don't plan on spinning her that high but I normally shift at 7200 to 7400 at the most. And the Boss mani makes peak HP at a out 7000 to 7200, and won't fall off it keeps making power! Shifting at higher rpm's keeps u in the power band. When u race u stay at high rpm's , when u drag at the track u stay at higher rpm's ! And that's where the boss makes the difference! U can feel it pulls harder from about 4500 and up! I will say if u are not a race or drag guy and u just putt and play DD than Boss mani is not the mod for u. I am staying N/A so I want every advantage I can get
And I didn't say no tires, I said 18" radials. I have Eibach Pro Kits, and a Steeda panhard bar to center my rear end. Other than that my suspension is stock.
Originally Posted by blackgt87
I understand some of the torque will come back with longtubes and the x pipe but that torque would still get added on even with a stock intake. You would just have WAY more.
7200-7400 is not enough rpm to make up for the torque loss, most people need to shift around 7600 just to pick up a tenth in the 1/4.
It's 11.74
I think you may be missing my point a little. I understand your car made good power, and I know you think that the power makes up for the torque you lost. But I'm saying you have no back to back comparison. Even a dyno won't accurately show which setup is faster. Just the hp and torque. Would you give up 25 ft lbs for 10 hp? How about for 25 hp? The real answer is you don't know unless you run the cars back to back against either a clock (a bunch of times for a good pass) or an unchanged car from a roll where traction and stuff doesn't matter. Until then your sotp or even dyno numbers don't mean squat. My buddy has an LS1 camaro that's 400 whp on the nose. It trapped 110 mph. The dyno doesnt always tell the whole story.
And no I don't think some speed shops selling parts and labor know everything. Just because they are a shop I'm not taking their word, maybe it's the engineer in me but I like proof.
But I'm saying run your car at the track with both intakes. Or race someone with both intakes.
And dude r u cereal? I had a boss intake on my car, how do you think I know? That's why I urge people to try both intakes back to back.
Didn't know u already had one. So what was the difference in ur times?? Are u manual? If so any mods to support?
That is by far the fastest time I have seen yet with those mods. Christ there is guys running that with longtubes, with your mods and full suspension.....
I think I get both your points.
BMeline is saying he likes the higher hp, and is willing to lose a little bit of torque.
BlackGT is saying the compromise of lower torque to higher hp (in the case of going with the Boss mani) may not be the best idea since the car may actually end up being "slower" (as evidenced by trap speed, quarter time, etc) as he has personally witnessed on his own car and others.
Am I right?
Both have good points.... but maybe BMeline doesn't care about being faster overall but just wants more hp in general???
Am I right?
Torque might help you get off the line but is not the most important thing to worry about. Just check out some really fast imports. High hp and low tq. But still fast. Hell if you want low end hp and torque just put a blower. If set up right, it can still put down some serious numbers.
Am I right?
Am I right?
And also, lower low end torque may help on launch traction issues. What gears are you running?
As stated above. I also think this is why my car got slower, I think you need a good host of supporting mods (including most importantly a throttle body and longtubes, as well as a lot of gear) to go with the boss or it will slow you down. A CAI and x pipe just won't cut it, and thats about as far as a LOT of people go with power mods. Which is why I keep harping on this, the boss intake is not for everyone.
Am I right?
Am I right?
I never seen any proof of what he is saying as far as cars with the Boss pulling slower times. There are people that go both ways with this topic but never any proof. He could be right or could be wrong, if he could give me proof that's another story. I will run the car at the track to see some results. If anyone wants to find out follow my build will try to post some results every chance I get. I put good power down on the dyno now have to see what it will do on the track
