Sponsored by:
Sponsored by:
It didn't take long and clunking noise?
Old Aug 12, 2013 | 10:08 PM
woodzusa's Avatar
Picked up my 2014 GT last weekend. I decided to get on it ( a little) and I was thrilled with the power. So , fast forward a few days and I've came to the conclusion I want more power. Already have the cai ready just waiting on the tune to be e-mailed to me. I fear that it will not be long before I will go FI .
Second point: I've seen this addressed in some other posts but wanted to ask for good measure. Do these 6MT or drive shafts all clunk when going into first and or second? Just noticed it after putting about 200 miles on the odometer.
Old Aug 12, 2013 | 10:10 PM
DarrenGT's Avatar
i notice some normal sounds when my top is down.
Old Aug 13, 2013 | 09:59 AM
thebms's Avatar
From speaking with the Ford tech (who drives a mustang) at my dealership, the 1-2 "clunk" is from the two piece driveshaft and happens if your not perfectly rev matched. Its more pronounced in lower gears.
There's also a 1-2 clunk from the gearbox that many experience with their mt's before everything's fully warmed up.
Old Aug 13, 2013 | 10:03 AM
Ltngdrvr's Avatar
No "clunk" on mine and I've run it plenty hard many times.
Old Aug 13, 2013 | 11:25 AM
thebms's Avatar
Do you have an auto or stick shift?
Old Aug 13, 2013 | 11:30 AM
KC Henry's Avatar
I have a couple friends who have the 6M's, and neither of their's "clunk", and my Auto doesn't "clunk".
Since your planning on doing a "CAI & Tune" you will Void any and all Powertrain Warranty's, so any issues from here on out with your 2014 will be out of your pocket.
Old Aug 13, 2013 | 01:05 PM
Ltngdrvr's Avatar
Manual
Old Aug 13, 2013 | 01:28 PM
PonyMuscletang13's Avatar
This.
Also, the clutch on 14s seem fairly loose (tested more than one) compared to mine - feels a lot heavier, more resistance the better control?
Old Aug 13, 2013 | 01:40 PM
woodzusa's Avatar
Thanks for the info ..
It is probably the driveshaft and the way I put it into 1st and into 2nd. Been awhile since I have driven a manual.
Old Aug 13, 2013 | 01:53 PM
Is this the first time you've had a track-lock diff? They are not noise free depending on the quality of your shift. Feather the throttle a little more.
The driveshaft is not at issue.
Old Aug 13, 2013 | 01:59 PM
rriddle3's Avatar
Originally Posted by KC Henry
...Since your planning on doing a "CAI & Tune" you will Void any and all Powertrain Warranty's, so any issues from here on out with your 2014 will be out of your pocket.
Well, Ford can say that all they want, but the Magnuson-Moss Warranty Act trumps it. Ford has the onus to prove that what you did contributed to any problem you may claim under warranty.
Old Aug 13, 2013 | 02:06 PM
2012GT's Avatar
That is NOT carved in stone. Case by case basis. If his u joints snap, his warranty isn't automatically voided because of a tune; especially if the car had for example 20,000 miles on the original tires. Then it would be pretty on obvious just because a car is tuned , it does not equal abuse.
Old Aug 13, 2013 | 02:18 PM
KC Henry's Avatar
Let's just say I work in a Stealership, and if a car manufacturer has the opportunity to "wash their hands" of an issue on a modded car, they will.
Anything you alter will Void the manufacturer warranty on it. Mod the powertrain and you void the powertrain warranty, Mod the exhaust, and you void the emissions warranty, mod the stereo and you void the electrical system warranty.
It is pretty cut and dry, and easy to understand even for the most "simple-minded" person .
Old Aug 13, 2013 | 02:30 PM
rriddle3's Avatar
What is your position at the dealer you work for?
Old Aug 13, 2013 | 03:10 PM
KC Henry's Avatar
Assistant Parts Mgr, so unfortunately I get wrapped up in issues like this from time to time.
Old Aug 13, 2013 | 09:54 PM
woodzusa's Avatar
Thanks for the info. I'm not greatly concerned with warranty coverage on the power train. The dealer has already said that they do not care if it is tuned and barring any destruction of the engine (hopefully not from a bama tune) then they would warranty it.
Besides if it gets a FI from Roush (next year) then it will be up to Roush to warranty it if it's installed at a Roush dealer.
Old Aug 14, 2013 | 08:30 AM
KC Henry's Avatar
Be careful with the Bama #8 Warranty, they have and will continue to decline their Warranty if they see fit.
Old Aug 14, 2013 | 02:35 PM
2012GT's Avatar
There are some "stealerships" out there that actually use common sense and don't void warranties just because THEY CAN. There are still some customer friendly "stealerships" out there. Not all are like yours that have an ego trip that get off telling customers what they can't do for them rather than what they can do. Void my warranty for my alternator going out because i upgraded my door speakers for example....makes perfect sense to me since I'm so "simple minded".
Old Aug 14, 2013 | 03:23 PM
KC Henry's Avatar
Stealerships will take care of a customer within reason.
If its something that is a hundred or two bucks, and the customer is a repeat client, sometimes they will "good-will" it, but you can bet that if you end up with a $7,000 Cyl#8 failure, they will find a way to pin it on the customer.
Don't take my word for it, just search all the different Mustang Forums, and you will see it has happened and continues to happen.
Old Aug 14, 2013 | 07:48 PM
PaxtonShelby's Avatar
I thought the Roush warranty was from the original sale date of the CAR, not from the date of the Roush purchase/install.
