Sponsored by:
Sponsored by:
cylinder 1 missfire help?
Old Apr 26, 2016 | 05:45 PM
Yunior32's Avatar
Well, i have a cilinder 1 missfire code, my wife had placed 91 oct on my car which is tuned for 93 oct, it was driven hard and according to bama it could be a spark plug that went bad or the coil, i replaced the spark plug and the code is still on, could it be i have to replace the coil as well? I dont want to just buy the coil which is 70$ and not solve the problem? Anyone else hd this issue in the past? The engine does kind of like a lagging sound.
Old Apr 26, 2016 | 05:47 PM
Yunior32's Avatar
Engine is lagging kind of like if it had cams
Old Apr 26, 2016 | 07:21 PM
14Glassback's Avatar
Swap the coil to another cylinder. Clear the code. See what happens. If the misfire moves with the coil... You have a bad coil.
Old Apr 26, 2016 | 08:15 PM
Yunior32's Avatar
Great! What if it keeps showing the misfire, what would be the next step? Check injector?
Old Apr 26, 2016 | 08:39 PM
I may be wrong but I think an injector is unlikely. Coils in my experience have a much higher failure rate. Technically you could do the same procedure though with swapping injectors.
Old Apr 26, 2016 | 08:59 PM
Yunior32's Avatar
Thanks man!
Old Apr 27, 2016 | 07:17 AM
mfc133's Avatar
If it's not the coil it could be misfire TSB:
tsb13-06-15.pdf
Old Apr 27, 2016 | 10:27 AM
Yunior32's Avatar
What is missfire tsb?
Detroit Steel
Jun 10, 2016 10:27 AM
orange3.9stang
May 1, 2016 07:33 AM
Praetorian730
Apr 24, 2016 06:56 AM
Msstang76
1994-2004 V-6
Apr 23, 2016 08:41 AM
