Sponsored by:
Sponsored by:
Custom tune @ tire size question
Old Feb 17, 2013 | 08:50 AM
Tron84's Avatar
Not that I am running a staggered setup (285/40-18 X 255/45-18) what tire size do I put in when requesting new tunes?
I assume the front tires due to the speed sensor? Not sure though....
Old Feb 17, 2013 | 12:35 PM
mikeyt03's Avatar
You want to find out the tire revolution for your specific tire. Each brand is different even in the same size.
Old Feb 17, 2013 | 12:42 PM
smitty's Avatar
I always assumed the rear tire size as I think the speed sensor is located where it can read the transmission output shaft? but I don't know for sure. Good question.
Old Feb 17, 2013 | 01:05 PM
Ministang's Avatar
In your case, it doesn't matter which size you enter, as both tire diameters are virtually identical, less than 1% difference.
Old Feb 17, 2013 | 04:53 PM
Tron84's Avatar
That makes it easy, what if they weren't that close?
Old Feb 17, 2013 | 05:32 PM
sloppymax's Avatar
Reading will be based on the rear tire.
Old Feb 17, 2013 | 07:12 PM
Tron84's Avatar
Ok so I just put in an order for new tunes from bama, it asks for REAR tire size.
Guess I never noticed that before.
Old Feb 17, 2013 | 10:22 PM
2012GT's Avatar
Rear tire size diameter is the issue. I used my GPS to dial it in exactly by mph. Even the tuner setting was off when I put on the new tires by putting in the new diameter. I had to do a little trial & error. Speedo is now 100% correct.
Diode Dynamics
Jun 12, 2018 03:26 PM
HMR-TYM
Jul 31, 2015 10:39 AM
