Coyote Turbo Fabrication
I searched a bit but didn't see many turbo threads on here. The only ones I came across were people who installed a Hellion single or twin system. Before people start flaming, I do know several excellent companies already provide proven turbo systems to the public be it single or twin. That's not why I'm making this thread.
I have the ability to perform FEA, CFD, and digital modeling via Solidworks. This thread will just be a placeholder for various information I gather pertaining to turbocharging the Coyote. That way, when more and more people start adding FI to their Coyote they wont make a million threads asking why their valves are floating or why their 38mm wastegate isn't keeping up with the flow. When I had my Genesis I made a thread similar to this one and everyone loved it. Hopefully the Mustang community takes it the same way.
There are lots of things to consider when wanting to DIY a turbo system for your car. Hopefully we can get insightful information on some of the topics below. It's not a comprehensive list just a starter to get the wheels spinning. (pun intended)
- Turbo Selection (single/twin)
- Tubing Diameters
- Tubing Routing
- Fueling
- Wastegate Selection/Placement
- MAF Placement
- Inhibiting Valve Float
I found this nifty article from Fast Fords website. It involves various power adders being added to the Coyote. One in particular caught my attention. In the spirit of this thread I think I deem in necessary to provide some insight on this. I have linked the article in question below so you guys may review it.
Fast Fords Turbo Coyote
In their article they are testing the Hellion single turbo system. As most of us know. It really left a bad impression on the initial buyers when it first came out. To this date, I do not believe Hellion has fixed the issues associated with their kit. If I may, I would like to offer up WHY I think this kit has issues and offer some insight on how it could be improved.
1) If you look at some of the photos in the article you can see that the crossover tubing to the initial merge (Y-Pipe) is quite small in diameter. Given the fact that the Coyote flows at over 100%VE in N/A trim I am curious as to how they ended up at that given diameter. (from searching on the net. I believe it is 2.25" someone correct me if I am wrong)
2) Another thing that strikes me as odd is the actual merge angle into the Y-Pipe. Sure it may work, but just because it works doesnt mean it's correct or efficient. The sharp angle that the passenger side crossover takes into the merge could possibly be inducing some serious turbulence at higher RPM. (possibly one of the reasons contributing to valve float at rpms above 6000.)
3) The last thing I can see right off the bat is the wastegate size. 38mm is definitely NOT large enough to accurately controll boost on such a good breathing motor. The shear exhaust volume from a Coyote at redline must be overwhelming that little gate. I am betting that is a source of excessive backpressure. (another reason valve float may be occuring at such low RPM)
Just food for thought. I have no REAL CFD data on the Hellion. I'm just going by what I've seen plastered on the internet and my by own turbo experience. Discuss?![Thumb](https://themustangsource.com/forums/images/smilies/thumb.gif)
Well. Since this thread took off to a running start. I'm going to offer up some more info. When I owned my Genesis I was going to fabricate my own turbo system. I bought all the hotside plumbing, V-Bands, cold side tubing, and couplers. Since I have traded that car in, I now have boxes of all these things laying around in storage. So I figured, why not make good use of it?
I have a GT3081R turbo "laying around" in a box. While the compressor is large enough for the 5.0, the turbine side is a lowly T3 to help spool on a smaller engine. Garett says the max displacement on this is 5.0L.. I will not be using this turbo for a multitude of reasons. One being that the 5.0 flows extremely well from the factory. At the top of the RPM band you'll choke out these smaller turbos.
Instead, when I have the available funds and have suffciently planned and designed my system I will be utilizing a Borg Warner S400SX3. I am undecided on the 71 or 75mm version. Being a single turbo system I am leaning torwards the 75mm for later potential if or when forged internals are installed. Here's the link for review.
http://www.agpturbo.com/borg-warner-...71mm-and-75mm/
Since the 5.0 has numerous documented backpressure issues with turbocharging. I am deciding whether or not it's beneficial to use two seperate 46mm gates in the crossover tubing. Or one large gate near the collector into the turbine housing. Possibly a Precision 66mm.
The Boss valvespring upgrade would be a MUST for me. Although their exact spring rates are unknown at this time.
![Screwy](https://themustangsource.com/forums/images/smilies/screwy.gif)
Good talk guys.
Yea. I feel as if I let the community down with that one. I had everything I needed to get started then I ran across an incredible deal on this California. I have no plans on getting rid of this any time soon so I will put my parts to use instead of them collecting dust in my storage building.
This forum is kind of like GenCoupe. If it's not made by a vendor or specifically endorsed by a "Mustang Shop" then they have no interest in it. It's okay with me. I'll periodically update this thread with CAD models available to be downloaded so anyone can take the schematics to a local shop or do it themselves. An open source turbo system if you will. I have no plans on making money off of it. I feel as if I can bring something out that isn't **** and has actual science backing up the capabilities then I think it will work out just fine.
Whoever moved my thread to the Mod section. Thanks!
Not sure if you could find the spring rates on the valve springs, I would suggest taking a look at the Roush valve springs since Boss owners who track their cars hard are replacing the stock springs with the Roush's since the stockers can explode it looks like.
Ive done a few turbo kits on every gen mustang since they turned to fuel injection. I bought a 2013 thinking a top mount signle looked easy and straightforward. W a canton vortech coolant tank, a slim fan and bmr lower rad support alot of room opened up. Im running a 76/75 billet wheel ceramic ball bearing precision w a 96 ar. And I have came to understand after remaking my hot side 3xs its gonna take 3.5 to 4" pipe to the turbo and to the downpipe and a bigger turbo. I know it sounds crazy but if you want to help back pressure you need 80mm+ w 114ish ar and min 3.5 piping on the hotside. Jpc set up has the least bends and is the simplest and I was able to run 4" from the y to the turbo and 4" down pipe but I took the swaybar off for this. Then I still had some valve float but I was using the precision I mentioned earlier w a t4 undivided flange. I switched it out for a v band flange journal bearing basic 84mm w a 114ar and now I have no more valve or back pressure issues. Just because you put stronger springs in dont mean the back pressure dissappear. Its still there and your engine is still working hard to move the exhaust because its bottle necked. Since then I used some of my old y pipe and hot side on another car. I think I found a simpler way to fix b/p issues. 2 44mm waste gates at each side of the y pipe near the manifold flange. But instead of using boost to operate them I took the packpressure test port at the base t4 flange I made and ran it to the wastegates. Then I installed a 20lbs spring in each. So at 10psi boost if you make over 20psi b/p it will open the gates and bleed it off . So you use the wastegates to reg b/p. because you want a 1psi boost to 2psi b/p if poss. This seems to work great, I couldnt believe it. Ive spent every weekend for 4months trying diff things. Does any of this make any sense or have I been up welding too long lmao
Jpc set up has the least bends and is the simplest and I was able to run 4" from the y to the turbo and 4" down pipe but I took the swaybar off for this. Then I still had some valve float but I was using the precision I mentioned earlier w a t4 undivided flange. I switched it out for a v band flange journal bearing basic 84mm w a 114ar and now I have no more valve or back pressure issues..
Like you said. Your 1.14 A/R works great because it has the ability to flow the massive amount of exhaust volume without being stressed.
![](https://2.bp.blogspot.com/-pq4D6BTuV20/UdSBnVrbwJI/AAAAAAAAC6A/yG3mE8-_JOA/s680/yeahsciencebreakingbadmeme.jpg)
Here are some items that may prove useful in creating a ton of extra room to route piping.
http://www.bmrsuspension.com/index.c...productid=1043
http://www.bmrsuspension.com/index.c...productid=1053
I've been researching electric slim fans to replace the large bulky stock unit and shroud. This would definitely open up a bunch of real estate. When I find a solution for that I will update this thread accordingly.
There are lots of things to consider when wanting to DIY a turbo system for your car. Hopefully we can get insightful information on some of the topics below. It's not a comprehensive list just a starter to get the wheels spinning. (pun intended)![Big Grin](https://themustangsource.com/forums/images/smilies/biggrin.gif)
- Tubing Diameters
- Tubing Routing
- Fueling
- MAF Placement
![Banghead](https://themustangsource.com/forums/images/smilies/banghead.gif)
Antigini-GT/CS
10/5/15 09:43 AM
9/10/15 12:44 PM
