Sponsored by:
Sponsored by:
Cat deletes
Old Nov 29, 2013 | 03:53 PM
bud4au01's Avatar
Cat deletes
Anybody put them on ? What differences should i expect other than bit louder?
Old Nov 29, 2013 | 09:26 PM
Ltngdrvr's Avatar
You get higher flow out of them, but remember, they require a tune or it will throw a code.
Old Nov 29, 2013 | 09:34 PM
DarrenGT's Avatar
new to modding here so what are cat deletes?
Old Nov 30, 2013 | 02:02 AM
DinoDoc's Avatar
cat deletes are pipes that go in place of where your catalytic converters go that have bungs welded in so you can still have your O-2 sensors in the exhaust. This in turn is much less restrictive thus freeing up HP, and makes the car a bit louder. When you delete the cats you have to have your tune adjusted to compensate for the change in back pressure ( I believe) and have your O-2 sensors turned off so the computer doesn't give off a fault code.
Old Nov 30, 2013 | 05:50 AM
GrabberBlue5.0's Avatar
A tune doesn't compensate for any changes in back pressure. It will do two things. Turn off the rear o2's which monitor the cats and also on these newer cars will turn off the COT feature. Nothing more.
Old Nov 30, 2013 | 03:55 PM
DinoDoc's Avatar
Thanks for clearifying that, see you learn something every day.
Old Dec 2, 2013 | 08:55 PM
steve03gt's Avatar
COT feature? You'll definitely notice more sound, raspier, and seem to free up power.
Old Dec 3, 2013 | 03:51 AM
Originally Posted by steve03gt
COT feature?
COT=Cat Over Temp
Old Dec 3, 2013 | 11:27 AM
steve03gt's Avatar
Figured that was what it was, but couldn't figure out the acronym
Old Dec 3, 2013 | 05:41 PM
70monte's Avatar
Isn't it against the law to remove the cats and if you are found out, aren't there big fines involved? I thought the cats on most new vehicles were pretty free flowing and that you don't see much power increase by removing them.
Wayne
Old Dec 3, 2013 | 06:09 PM
Wayne
It is against the law in MA. You can get high flowing cats aftermarket as well.
Plus, like you said, it doesn't free up a ton of horsepower.
Old Dec 3, 2013 | 10:09 PM
ted2006's Avatar
illegal in all 50 states
Old Dec 3, 2013 | 11:54 PM
DinoDoc's Avatar
Cool
I thought I read some where that you could gain in the neighborhood of 15 HP with a off road X-pipe with cat deletes, Is this true?
Lee
Old Dec 4, 2013 | 02:37 PM
Lee
True.
Old Dec 10, 2013 | 06:44 PM
Toxix's Avatar
Good info here.
Do highflow cats provide the exact same power output/results as cat deletes?
How do high flow cats sound compared to no cats?
PS - 2014 GT here with Rough Axlebacks and Resonator Deletes already, heh.
Old Dec 11, 2013 | 02:25 PM
Originally Posted by Toxix
Good info here.
No they don't.
Old Dec 19, 2013 | 04:53 PM
Fudge's Avatar
I was thinking of doing this myself (actually bought them already) in your opinion (for those that have done the cat delete) are they worth it? do you get drone?
Old Dec 19, 2013 | 05:55 PM
woodzusa's Avatar
I have a convertible with the quad gt500 exhaust. I decided to remove the cat's using the jegs delete pipes. Fit was good, although we had to adjust the driver side to get rid of an exhaust leak.
Now, at first I thought they were too loud and the fumes were a little strong. Well, I guess the fumes killed some brain cells because now I love to hear them. And I no longer get an strong odor. There is some but not overpowering.
In the vert, it is loud during hard acceleration but tame when cruising.
People have their own opinion with and HP/TQ gains. But it seems more responsive since they were removed.
Old Dec 21, 2013 | 06:46 PM
dreday23's Avatar
yea i just got my steeda cat deletes installed and there is definitely something about the drivers side that doesn't allow aftermarket pipes to connect to the h pipe correctly. after using permatex and adjusting the clamp while the car was running theres still a very slight exhaust leak on the driver's side with the permatex being fresh. the passenger side doesn't leak however.
Old Dec 23, 2013 | 10:26 AM
Fudge's Avatar
The odor were talking about is fuel, I'm gonna guess, how bad is it? I start my car in a garage so the engine builds some heat before I leave, would this be bad? Is it syringe bought that idling for 2-3 minutes will cause me unintentionally commit suicide?
Or is is just a bit stronger than stock?
I noticed a bit of a fuel smell just going with a Steeda 93 octane tune, on guessing this will be more than that?
Or since the cats aren't doing anything anyways till they warm up the initial start up is not gonna make too much of a difference?
