Car and Driver: GT Short Take Road Test
After reading several reviews the diversity of opinions strikes me. One magazine says the transmission is heaven-sent, another describes it as notchy. C&D says the shift lever is too short, another review says it should be shorter. One magazine says the steering is too light, one says it's great. One says the V6 sounds great, one says it's ho-hum (sounds too V6-like), one says it's buzzy above 5000 rpm. The one thing though, that everybody agrees on is that the Coyote is one fabulous engine. Whether it's the power delivery, it's willingness to rev, or it's sound, everyone loves this new V8. And it seems that everyone agrees that Ford has massaged the suspension into the best handling SRA car ever.
I would say it's a relative thing. For a DOHC 5.0L with a 7,000rpm redline that is as flat and broad as Kansas, relatively speaking. Of course, it will never compare to low revving big blocks or blown mills like the one in the GT500 or even the Ecoboost 3.5L where you really do get torque curves that most closely resemble a ruler when demonstrated on paper.
You can find hundreds of dyno sheets with flat torque curves. I still say that the sheet for the 5.0 has a very flat torque curve pulling over 250 foot pounds across the curve with a 365 peak is plenty flat.
Swamp Donkey Aficionado
Hm...what constitutes a "small-displacement" V8? I tend to think the dividing line between small and large would be small <= 4.5, large >= 5.0, with 4.5 - 5.0 being a gray area. Interesting to think about. I'm sure others would put the line elsewhere.
There are whole lot of > 5.0 engines. That gives me reason to say 5.0 might be small or mid displacement. I would call the 5.7, 6.1/6.2 hemi's as high displacement. I would call the 5.7/6.0/6.2/7.0/etc LS engines as high displacement.
THe 5.0? It would be in the grey area at best.. I guess to use your scale, my grey area would be closer to 5.0-5.7.
Seems its as fast as a STOCK 2004 Mach1, They ran 13.1
http://www.musclemustangfastfords.com/vi...index.html
