Sponsored by:
Sponsored by:
Can the OBD II Speedometer data be fxed to give a correct signal past 160MPH?
Old Jun 8, 2012 | 05:09 PM
TK421's Avatar
I was just wondering if anyone had a work around for this. I am using a Racepak IQ3 with the OBD II interface. As soon as the vehicle reaches 160, the MPH display rolls over, thus 160 read as 0, 161 reads as 1 mph and so on. I believe this is a problem with the OBD II data and not so much the Racepak module. If the setting can be changed within the ECU then I will have my tuner take care of it. If there is a limitation in the sensor then I suppose it cannot be fixed.
Old Jun 8, 2012 | 06:11 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
Moved per request
Old Jun 14, 2012 | 01:47 PM
TK421's Avatar
Bump for some help.
Old Jun 17, 2012 | 03:26 PM
Ordie's Avatar
Do you really hit 160 often enough for this to be a major issue?
Plus why is it an issue? Seems like it would be a good thing, instead of just not indicating anything at all.
Old Jun 21, 2012 | 06:58 PM
TK421's Avatar
When the vehicle does see these speeds, I would really like to have an accurate way to see speed at a glance rather than doing math at such speeds.
The vehicle is primarily a race car, it only sees these speeds when set up for standing mile events. Here is a video, you will see the speedometer freak out around 160 MPH.
Old Jun 21, 2012 | 07:23 PM
MyStang2010GB's Avatar
Impressive!!
Old Jun 21, 2012 | 07:37 PM
Ronin38's Avatar
Can you use a GPS-based unit, instead of the onboard OBDII information?
I don't know what the "rules" are for those events...
Horsev6
Sep 21, 2015 10:27 AM
samjluck
Sep 17, 2015 10:24 PM
Allen Hanback
Sep 14, 2015 04:37 PM
Sep 8, 2015 10:45 AM
