Sponsored by:
Sponsored by:
Boss intake manifold and the evil of emissions
Old Jul 4, 2015 | 06:58 PM
Mr. V's Avatar
I am considering the boss intake manifold. I've tried searching everywhere to find out if my car will pass smog in California with this mod. I know many people will say just swap it back when the time comes for a smog check. I'm tired of doing that. I've done It in the past with other cars and it just annoys me. I'd rather just change a part and leave it on. I am hoping someone here knows about this.
Old Jul 4, 2015 | 07:34 PM
BackroadGT's Avatar
Mr. V , good question, unfortunately I don't have an answer. As a fellow goldenstater held captive by the powers that be, I would like to know as well. Did'nt the boss 302 come 50 state emissions legal from the factory?
Old Jul 4, 2015 | 11:17 PM
Mr. V's Avatar
I was thinking the same thing. It comes from a car that is smog legal but I don't want to throw it on and end up being angry that I have to go back to the original manifold.
Old Jul 5, 2015 | 04:29 AM
boss man's Avatar
Yes it's legal. Just like Track Key is legal. This is what killed the orginal lopy idle and why it took many months for Boss owners to be able to get track key. Call Ford Racing for the best answer.
https://fordperformanceracingparts.c...ontactfrpp.asp
Old Jul 6, 2015 | 12:41 PM
Mr. V's Avatar
Thank you for the suggestion. I have no idea why I didn't think of that. I just got off the phone with them and it's not smog legal. That is a deal breaker for me. I'm more than a little disappointed.
Old Jul 6, 2015 | 06:39 PM
BackroadGT's Avatar
Is that because the intake is not a factory part on the GT? Or are the cats different on the boss 302?
Old Jul 6, 2015 | 06:56 PM
Mr. V's Avatar
The rep on the phone said it was due to the tune. There is no way for it to be smog legal. This surprised me because I know galpin motor sports installs this win new cars. I assumed it had to be legal but I wanted to be sure. The rep on the phone said definitely not legal
Old Jul 9, 2015 | 08:55 AM
BadHabit2Break's Avatar
Don't know about Cali, but here in Tx, I have passed with my Boss IM and on E85.
Old Jul 9, 2015 | 01:53 PM
ConeBoss's Avatar
I was also going to say, just because they say it's not legal does not mean it wont pass. I don't see why you could not just have a "Smog" tune that you spend 5min loading into the car before testing to ensure you pass.
Where there is a will, there is a way!
Old Jul 10, 2015 | 07:56 AM
It's all with the tuner. All my emission monitors pass in 66 miles on both 93 and E85 tunes.
Old Jul 13, 2015 | 12:32 AM
Mr. V's Avatar
California has a visual inspection component to the smog test. You can pass the tail pipe portion and be failed based on visual. They look under the hood and if anything is modified, you fail. I'm not sure if most smog techs would know what the intake manifold should look like. I'm afraid I'd fail the visual and half to put the old intake manifold back on.
Old Jul 13, 2015 | 08:29 AM
MKMotorsport's Avatar
Should and will pass just fine. Its an OEM part. When installed correctly, with all the supporting lines installed correctly, it should pass. You are not changing the wet fuel flow path, simply the air. I've been running my Boss on my GT for ~10k mi and never tripped a check engine or wrench light... 100% stock drivability.
Old Jul 13, 2015 | 10:54 AM
MRGTX's Avatar
Can I just throw a wrench into the equasion here??
Why do you want the Boss manifold? Unless something has changed in the past year or so, the conventional wisdom was that unless you had a built bottom end that could take advantage of ~7500 RPM, the Boss manifold is only going to slow you down.
Remember that the Boss has different rods, pistons crank(?) valuetrain, etc. that allow the motor to rev higher and benefit from that intake.
Just playing the devil's advocate...
Old Jul 13, 2015 | 11:49 AM
tom281's Avatar
It won't slow you down with the right tune you'll see nice gains above 5500 rpm. The problem is when people that think it will make their car fly with just bolting it on with a canned tune.
Old Jul 13, 2015 | 11:57 AM
Mr. V's Avatar
I have 2 reasons that won't sound very impressive but I'll share them. One is that I just love the way it looks. The second is the power delivery seems smoother. I drove a friend's boss and loved the way it felt. I was driven in a gt with the boss intake manifold and a custom tune and it seemed to have that same smooth power delivery. My car seems like a big gob of power smacks you suddenly. I love it now but I think I'd enjoy the boss intake more.
Old Jul 13, 2015 | 03:46 PM
You just need to find the right smog place, that takes cash and passes your car without even hooking it up to anything
Old Jul 13, 2015 | 04:03 PM
This is because most people just parrot what others say, with no firsthand experience. It's quicker even with the miserable stock gears and converter. ET was ~ the same as stock manifold but mph was 2-3+ The car for sure makes MORE HP with it as evidenced by the higher mph (all else the same)
-Must retune and rev the motor harder than stock (I've had no issues) to make use of it.
-Must port it and clean it up. Mine was from the get go and have no experience with an "out of the box" stock one.
-Better if you have a better matching TB and intake tract.
-WAYYY better to have some gear + converter, Or ALOT of one if not the other
Old Jul 14, 2015 | 04:48 AM
Speedwagon's Avatar
Move to a different state other than Commifornia ...
Old Jul 14, 2015 | 07:31 PM
5.M0NSTER's Avatar
But...but.. it knows how to party!
Old Jul 14, 2015 | 10:37 PM
Let's keep it rockin?
