Notices
AIRAID intake Tube for Stock Airbox
Old 8/3/14, 07:01 PM
solscooter's Avatar
Unhappy
That looks really good! I think I'm going to do this. Where you'd pick up the C&L?
i bought it off a forum member on svt. they don't make them anymore
Old 8/3/14, 07:03 PM
dmhines's Avatar
Originally Posted by 65sohc
Wow! That's super-cool. I have already measured the difference in intake restriction (negative pressure ahead of the throttle body) between stock and my C&L using a manometer. The difference is substantial: 18 inches of water. I never attempted to determine where the restriction lies. I just compared the entire assemblies. I didn't realize you could use the C&L tube with the stock airbox. I'm going to try that and measure the restriction of the "hybrid" intake. If it's the same as the factory we'll know the box is the culprit. If it flows as freely as the C&L with open element we'll know the tube is the restriction.
Cool.
Here is what airaid says:
Constructed of cross-linked, high-density polyethylene, the AIRAID® MIT provides a smooth path to the throttle body that flows up to an additional 400 cfm over restrictive stock intake tubes.
Old 8/3/14, 07:10 PM
65sohc's Avatar
Hmmm. I was under the impression that C&L used the same tube for the Boss and the GT. I just tried to mate my stock air box to the C&L tube and found it is much larger than the factory filter housing outlet, even using the C&L silicone reducing coupler. Oh well. I'm not particularly concerned with IAT at idle anyway.
Old 8/3/14, 07:12 PM
65sohc's Avatar
I had already strategically located some pieces of foam to close up some gaps in the C&L heat shield so mine actually works somewhat better than when I first got it.
Old 8/3/14, 07:23 PM
solscooter's Avatar
you are correct the tube for boss and gt should have been the same. i really tightened it down on the air box end. if it turns out to be a problem i can always throw the filter back on. no vacuum leaks that were readily noticeable. ill get the soapy water tomorrow and double check. ran it pretty hard this afternoon and didn't notice any problems.
Old 8/3/14, 07:29 PM
solscooter's Avatar
Originally Posted by FromZto5
Looks great! CnL a good brand? What color filter?
thanks, C&L was around a long time but from what i understand closed recently unfortunately. their website is still up but you can't purchase anything. the filter is actually that K&N maroon
C&L site
Old 8/3/14, 07:52 PM
5LHO's Avatar
Be careful...you don't get vacuum leaks ahead of the throttle plate so, a leak here is can just ingest crap into the motor or unmetered air, without noticeable effect. That's how engines get burnt up.
Old 8/3/14, 09:34 PM
Of course...
Old 8/4/14, 05:02 AM
solscooter's Avatar
Thanks for the heads up
Old 8/4/14, 12:20 PM
BBM3's Avatar
Soapy water works great for identifying pressure leaks.
For vacuum leaks with the engine idling spray a mist of carburetor cleaner at the joints. If there is a leak the idle will rise.
Old 8/4/14, 02:32 PM
solscooter's Avatar
Originally Posted by BBM3
Soapy water works great for identifying pressure leaks. For vacuum leaks with the engine idling spray a mist of carburetor cleaner at the joints. If there is a leak the idle will rise.
You are totally right. Not sure how my brain managed to misplace this info. Thanks
Old 8/4/14, 02:57 PM
BBM3's Avatar
No problem.
Just to be safe.
You might want to spray some carb cleaner on a Q-tip and dab a drop on the plastic parts in an inconspicuous place to make sure it doesn't soften, or turn the plastic white.
The silicone coupling will be fine.
Old 8/4/14, 08:11 PM
Was going to use airraid but their elbow won't fit the Maggie. So...roush intake with Maggie elbow.
The airraid was a great piece when I had it, back when I was NA.
Attached Thumbnails AIRAID intake Tube for Stock Airbox-image-3312823932.jpg
Old 8/4/14, 08:33 PM
Getportfolio's Avatar
Originally Posted by dmhines
Got it installed. Looks good .. except for AirAid logo .. need to find a Ford logo or something to fit there. Pretty sure its making the car sound a little meaner ... Throttle response does feel better but could be my imagination. The parts and components are all very high quality ... which they should be for $125 ....
The trunk emblem from a 2001 Escort is a perfect fit. I kid you not. Looks awesome at that.
Old 8/4/14, 11:27 PM
dmhines's Avatar
Thanks. I found and aftermarket Ford emblem on ebay that is 3.75 inches and bought that one. Will see how it fits.
Old 8/6/14, 10:40 AM
TommyV's Avatar
AM now sells C&L, maybe they bought 'em out.
http://www.americanmuscle.com/cnl-in...gt-notune.html
Old 8/6/14, 04:20 PM
solscooter's Avatar
Originally Posted by TommyV
AM now sells C&L, maybe they bought 'em out. http://www.americanmuscle.com/cnl-in...gt-notune.html
Could be. Rumors were that someone was buying the company. That was a few months ago. Haven't heard anything since then
Old 8/6/14, 06:16 PM
65sohc's Avatar
You know what's funny is that AM charges $20 more for the "Racer" version which is exactly the same as the "Street" version minus the no-tune MAF insert. In essence you pay more for less.
Old 8/8/14, 12:05 PM
ruizjr01's Avatar
That Looks really nice. I am interested in getting this for my 2014 5.0 but was wondering if the Airaid tube has a MAF sensor relocator, or is it just the tube? I currently have the Roush Air Filter kit and want this tube attached to it.
Thanks,
Johnny
2014 5.0, Automatic, Deep Impact Blue
Bama 93 Race Tune, Roush Axle Back
Everything else is stock...for now
Old 8/8/14, 02:13 PM
  #40
dmhines's Avatar
The MAF sensor stays on the factory airbox .. the AIRAID is just the tube.
Quick Reply: AIRAID intake Tube for Stock Airbox
