Sponsored by:
Sponsored by:
Aeroforce Interceptor Gauges ?
Old Aug 1, 2011 | 08:53 AM
way2qk4u2c's Avatar
I'm thinking about getting Dual Interceptor gauges so i can display 4 things at once. Now the questions is what would be the 4 most important things to monitor- especially if you have a tune?
1.
2.
3.
4.
I know everyone will have a different opinion and ideas so lets hear them!
Old Aug 1, 2011 | 11:39 AM
jsnyng's Avatar
I monitor the following with mine:
1. Air Fuel
2. Intake Air
3. Coolant Temp
4. MPH (just because I don't like the analog gauge)
Old Aug 1, 2011 | 12:38 PM
Ronin38's Avatar
I have a single Interceptor gauge in my car.
I have the auto-trans, and was hoping to monitor Trans Temp. and Actual Gear, but those are unfortunately NOT available. I don't know if Trans Temp. works for the Manual. I've emailed Aeroforce to try to get some help, but so far no results.
I have been monitoring my IAT, and frankly it's not needed. With the stock air box, the IAT is always less than +5 from Ambient when you're moving more than about 40 mph.
I have the LED Annunciator set to +230 Coolant Temp., and I monitor various other values, depending on what I'm doing.
Old Aug 1, 2011 | 12:41 PM
way2qk4u2c's Avatar
interesting...Well i dont have a auto and manual you cant read the temp on it.
I dont have the stock airbox
Old Aug 1, 2011 | 01:44 PM
S197 GT's Avatar
3rd Times A Charm
1. A/F Bank 1
2. A/F Bank 2
3. MPH (****s and giggles)
4. RPM (****s and giggles)
Once I get the blower on, I will change the bottom values to Boost and Fuel Pressure.
Old Aug 1, 2011 | 01:49 PM
way2qk4u2c's Avatar
Sweet so once i get a blower having 4 things to monitor will come in handy
I want to go with the BOSS gauge pod and put 2 of these in and then a single one just for boost eventually down the road.
I was thinking
1. A/F bank 1
2. A/F bank 2
3. Oil pressure
4. Fuel Pressure
3rd gauge boost
Old Aug 1, 2011 | 02:13 PM
Doogie's Avatar
Keep in mind that you can cycle through up to 8 (IIRC) parameters on each gauge and non-essential things like boost can easily be added to one of your Aeroforce gauges with an analog 2-bar MAP sensor, instead of adding a seperate gauge. I usually display boost/fuel pressure and IATs/coolant, but change it up once and while.
Old Aug 1, 2011 | 02:15 PM
way2qk4u2c's Avatar
^^ correct so instead of a 3rd gauge for boost what would you put in the extra spot in my 3 pod gauge holder?
do you have any pics of your gauges?
also what color combo do you think will match the '11 interor the best? i was thinking white face with white lcd and black numbers
Old Aug 2, 2011 | 08:36 AM
S197 GT's Avatar
3rd Times A Charm
Here's mine
Old Aug 2, 2011 | 08:43 AM
way2qk4u2c's Avatar
^^nice... looking to do the samething just on top of the dash like the BOSS.
Old Aug 3, 2011 | 01:51 PM
drewzx3's Avatar
How do you run a dual gauge setup? Thought they plugged in to the Obd port
Old Aug 3, 2011 | 01:52 PM
jsnyng's Avatar
They provide you with an OBD II splitter cable when you order a dual setup. It's one cable that plugs into the OBD II port and then splits further down the line.
way2qk4u2c's Avatar
splitter connector to allow for 2 devices on the OBD
Old Aug 3, 2011 | 02:17 PM
jsnyng's Avatar
You got tree'd.
Old Aug 5, 2011 | 10:08 AM
Hytek's Avatar
Originally Posted by S197 GT
Here's mine
Just when I thought I was done for a little while with mods I see this... Very nice! Is that the guage pod from AM?
Sorry for my ignorance, but would monitoring air/fuel ratio be beneficial with CAI and tune?
Old Aug 5, 2011 | 10:32 AM
S197 GT's Avatar
3rd Times A Charm
I got it direct from Speed of Sound. Alan is a good buddy of mine, and he'll have my business for life!
I think it'd be smart to monitor A/F on an NA setup because of all these #8 piston issues. You can see if you're running lean.
However, this will average the A/F ratios across the entire bank, so it'd still be hard hard to determine if #8 is leaning out.
Old Aug 5, 2011 | 10:38 AM
BlackOut2k11's Avatar
I'm thinking of monitoring AFR with my CAI and tune, just to have a visual of how "safe" I am.
Old Aug 5, 2011 | 11:18 AM
Hytek's Avatar
Good to know. Thanks. I think I'm going to consider these now.
How hard was it to install the pod?
Old Aug 13, 2011 | 03:10 PM
Vectors2Final's Avatar
These gauges are straight cash!!! Did they come with the mounting harware? S197GT?
Old Aug 13, 2011 | 04:53 PM
S197 GT's Avatar
3rd Times A Charm
Nope. No mounting hardware.
I got a Speed of Sound pillar, and these fit with friction.
