Sponsored by:
Sponsored by:
2012 traction
Old Jun 9, 2013 | 08:54 PM
Tominkc's Avatar
Good evening everyone from KC!!
I have a question!! I have a 2012 GT, and it's been lowered 1.25"!! I still have the stock LCA's on! It's also. 6 so manual!! With stock tires! But I can be cruising at around 50 mph and down shift let the clutch out than floor it, the rear end squats does and takes off like a rocket, but than the tires break loose and starts spinning and the next thing I know I'm redlining . So I was wondering if I got new LCA's with new relocating brackets and mount them to the 2nd hole, would that help!!
I'm planning on going and get wider tires, like 285x19. I heard that these tires won't rub!!
Also from a dead stop and taking off, I don't get any wheel hop at all, but it's the same, the rear end squats down, it takes off like a rocket, but once it hits the power band, that's it, tires break loose and the rear end all over the place!!
So any help would be great!!
Old Jun 9, 2013 | 09:25 PM
Marcin K.'s Avatar
I've actually been curious about the same thing.
I plan on taking my car to road courses, and I'm interested to hear what the best size is for that. My car comes with 255/40-19, and I've been contemplating 275/40-19 or 285/35-19. I'd like to avoid staggered configuration if possible.
Will I be able to fit these tires up front without rubbing on 19/9.5 wheels? I'd appreciate some input from those of you who tried it. Thank you!
Old Jun 13, 2013 | 10:06 AM
kona stang10's Avatar
Your headed in the right direction, yes upgrade the lca, and add relocation brackets. the 285/35/19 will fit even all the way around with no rubbing. But the most important piece is to get a uca and bracket. all these in tandum will get you the grip you looking for without the squat!
Old Jun 13, 2013 | 05:57 PM
Ponywars's Avatar
Definetly on the uca along with the lower!
Old Jun 14, 2013 | 08:18 PM
dmichaels's Avatar
I am still breaking my car in so haven't really touched redline much at all but I get a little wheel slip in 1st then 2nd seems to hook up real nicely... I have the track pack with 255 tires that are be 220 tread wear rating, so quite sticky.
To the original question wider all around seems to be pretty common with the road racing folks. I will probably do 285-295 rears and 275 fronts on 18" wheels for a track setup. For the street I would think if you went with OEM size but stickier compound you should be able to hook up nicely
Old Jun 16, 2013 | 05:40 PM
Marcin K.'s Avatar
Can you fit 18" rims over the Brembos up front?? If so that would certainly be a less expensive way to go. What would be the aspect ratio of this setup. 285/40/18?
Old Jun 16, 2013 | 11:51 PM
MadMoose's Avatar
I had the 18x9.5 2007-09 Gt500 wheels over the brembos on my boss just fine. Tires were 255/45/18
Old Jun 17, 2013 | 08:26 AM
Marcin K.'s Avatar
Thanks MadMoose, that helps a lot.
Old Jun 17, 2013 | 02:10 PM
14Glassback's Avatar
That amazes me 18's would fit over the Brembo Calipers!... Looks pretty snug with the OEM 19's to me... But just goes to show you it never hurts to try! Good to know!
Old Jun 17, 2013 | 02:59 PM
MadMoose's Avatar
Snow tires!
Old Jun 17, 2013 | 04:15 PM
Gabe's Avatar
I'm running 275/40R18 all around on my '13 Track Pack (Brembo brakes) on '10 GT500 18x9.5 rims and love the look and better handling and extra bite from the new tires (Continental DWS)
Old Jun 17, 2013 | 08:09 PM
Marcin K.'s Avatar
Wow Gabe, car looks SHARP .
Looks like the wheels juuuust clear those huge Brembo calipers
Thanks for the info, it's definitely good to know.
Old Jun 17, 2013 | 09:47 PM
Gabe's Avatar
Thanks Marcin .... they had to clear, the brakes are the same ones Ford used on the GT500 until the '13 model, the rims are GT500 rims
There's actually a little more room between the caliper and the back of the spoke, compared to the stock Brembo wheels that came with the car.
Also, these are 9.5" wide and have a 45mm offset, whereas the stock Brembos are 9" wide with a 42mm offset, so these stick out about 3mm more (about 3/16").
cameron2581
'10-14 Interior and Audio
Nov 26, 2015 01:26 PM
boz
Oct 1, 2015 04:47 PM
Horsev6
Sep 21, 2015 10:27 AM
Sep 8, 2015 10:45 AM
