Notices
2011 mustang help
Old 2/26/12, 05:10 PM
jefframrod's Avatar
2011 mustang help
I recently put 275/35/19 all around, eibach pro series springs, RTR rims and my car feels very loose when cornering and does not handle like stock can anyone help me out and tell me why its like this and what I need to fix the problem
Old 2/26/12, 05:34 PM
Hytek's Avatar
Where is the loose feeling coming from, front or rear?
Old 2/26/12, 05:53 PM
jefframrod's Avatar
Mostly the rear but front as well seems like I'm getting a late response when switching lanes quickly kinda weird cause stock was so responsive.
Old 2/26/12, 05:59 PM
Bigblue11's Avatar
What tires are you using? Are you still using the stock shocks, panhard and strut mounts?
Old 2/26/12, 06:03 PM
what tire pressures are you running?
Old 2/26/12, 06:05 PM
jefframrod's Avatar
I'm using nitto 555, other than that everything else is stock, no panhard bar, strut mounts the only thing I did was add the eibach pro series springs and kept everything else stock.
Old 2/26/12, 06:10 PM
jefframrod's Avatar
Tire pressure 35
Old 2/26/12, 06:19 PM
kona stang10's Avatar
Center that rear with an adjustable pan-hard bar make sure the wheel width is acceptable for that tire size, your rims should be 10 inches wide for that tire. 9 inches is not wide enough and will cause stability issues.
Old 2/26/12, 06:20 PM
jefframrod's Avatar
And I just don't want to start replacing everything cause I really don't know what I need that will fix the problem.
Old 2/26/12, 06:23 PM
Hytek's Avatar
Your problem sounds pretty odd. I have the same wheels and tires. I also installed my springs on stock dampers the same day the tires were installed and my ride tightened up quite a bit and cornered great. How much of a drop are those springs?
Old 2/26/12, 06:25 PM
Hytek's Avatar
Any noises, creaks, pops? Something could be loose on the front or over tightened possibly?
Old 2/26/12, 06:28 PM
jacostang's Avatar
Add the panhard bar but really there is something not right for it to be loose... It should have a very snug feel....
Have you had it aligned yet? They will check all your components for you...
Old 2/26/12, 06:32 PM
jefframrod's Avatar
Drop was 2in rear 1.5in front what tire pressure are you running?
Old 2/26/12, 06:34 PM
jefframrod's Avatar
We did alignment when @ dealership
Old 2/26/12, 06:35 PM
Hytek's Avatar
That's a pretty significant drop to still use stock dampers. I would do like said above, go get an alignment asap. With that much of a drop there's bound to be something out of alignment.
Edit: Nevermind the alignment, just noticed you had it done already.
jefframrod's Avatar
Not sure what deal is feels very sloppy
Old 2/26/12, 06:40 PM
jefframrod's Avatar
You said you have same set up, what tire pressure are you running
Old 2/26/12, 06:43 PM
jacostang's Avatar
I run 35 PSI. It might be the whole combo, those n=Nittos need some heat in them to stick but iwht that drop you def. need a Pan hard bar, they are not expensive... BMR makes a very good one..
Old 2/26/12, 06:44 PM
jefframrod's Avatar
Thanks jacostang I guess ill take it to dealership and have them check it out.
Old 2/26/12, 06:45 PM
jefframrod's Avatar
So you think that will fix my sway
Quick Reply: 2011 mustang help
