Sponsored by:
Sponsored by:
2011 brembo brakes
Old Jul 24, 2010 | 07:03 PM
jaguarking11's Avatar
2011 brembo brakes
I was wondering if anyone has any info on the brembo package.
From my reading it has 4 pot rear brakes as well? Any info on these? will they bolt up to a 05-09 rear? if so is the master cylinder different?
Old Jul 25, 2010 | 08:19 PM
Driver72's Avatar
4 pot front
2 pot rear
Old Jul 25, 2010 | 09:13 PM
Ltngdrvr's Avatar
Originally Posted by Driver72
4 pot front
2 pot rear
I don't think the rear is even 2 piston, think it's just a single piston, same rear calipers and rotors as standard GT.
Old Jul 25, 2010 | 09:18 PM
Even a 2011 GT500 SVT PP has the same calipers and rotors as a regular 2011 GT on the rear. Or a 2010 GT for that matter.
The GT500's have upgraded pads though on the rears, not sure about the Brembo 5.0s.
FWIW
Old Jul 26, 2010 | 12:30 AM
I guess it was a misprint. I saw autoblog mentioned 4 piston rear calipers for brembo package 2011 gt's.
Reason I ask is because I did the brembo upgrade to my 07gt. Love the brakes, but the rears went dead on me before. I dislike the rear calipers & pads for a few reasons. None have anything to do with braking performance but rather longevity & maintenance.
I don't like the fact the rears are sliding calipers, they can get stuck or wear pads unevenly.
I hate the fact that the rear also have no squeal tabs on the pads therefore they need constant atention, whitch would not be so bad but rear brakes are a pain to check, especialy since the pad that wears first is hidden by the dust sheild.
Thanks for the info guys. Much apreciated.
Old Jul 26, 2010 | 06:50 AM
sqidd's Avatar
Well the rears must work pretty good. The FR500 uses them.
Old Jul 26, 2010 | 10:44 AM
I agree on all counts.
Old Jul 26, 2010 | 11:31 AM
I never said they did not perform well. I said they need to be better designed. Myabe next time you have to use the stupid twist tool to put the piston back in the caliper and have to have your rear rotors turned you might rememeber my complaints.
You don't have to turn rotors on modern disc brakes unless you either abuse them or the pads wear down to metal and you end up screwing your rotors up. In both cases I would rather replace the rotors instead of turning them.
Old Jul 26, 2010 | 12:03 PM
Automagically's Avatar
I have seen the Brembo kits for the 05-09's with the upgraded GT500 rear brake pads. Not sure if they are that much better but I am sure they are decent Hawk pads or similar. Probably what I am going with when I get an earlier S197.
Old Jul 26, 2010 | 07:09 PM
Driver72's Avatar
It might of been a misprint too, but I read in a magazine the Brembo BP got 2 piston rears.
Honestly I'm quite surprised nobody with a 2011 GT actually knows this for sure yet.
Old Jul 26, 2010 | 08:53 PM
OAC_Sparky's Avatar
According to the dealer guide it's 4 in front, 2 in the rear just like the Shelby.
Old Jul 27, 2010 | 03:34 PM
sam strano's Avatar
The rears are the standard single piston rears...... I'm pretty familiar with them from my '07 GT and the '07 Shelby GT.... and my '11 Brembo car has the same rears.
Old Jul 27, 2010 | 08:44 PM
Jott's Avatar
"For some reference, here's what the $1695 Brembo Package entails:
-- Front 14-inch Brembo vented rotors with Brembo four-piston calipers
-- Rear 11.8-inch vented rotors with four-piston calipers
-- Unique 19-inch wheels
-- Summer performance tires
-- Unique suspension
-- Unique electronic stability control and steering tuning
Source: Ford"
According to this article the rear has 4 pistons?
Soooo.... who is going to take theirs apart and take pictures?
Old Jul 27, 2010 | 09:44 PM
Ltngdrvr's Avatar
You don't have to take anything apart to tell that they DON'T have 4 piston calipers on the rear.
All someone needs to do take a pic through the wheel with the caliper set between the wheel spokes.
Old Jul 29, 2010 | 02:20 PM
hawkeye18's Avatar
my order confirmation states 2-pot rears.
Old Jul 29, 2010 | 02:39 PM
Thew article is wrong. Go to Fords website, build a Stang, and then when you get to the options the Brembo package clearly states 2 piston rear calipers on 11.8" (I think) vented rotors. Plain as day.
Old Jul 29, 2010 | 05:46 PM
ScottH's Avatar
I second this. Click the details button for the package and it states 2 pistons in the rear. Now, if Ford made a boo-boo and put inaccurate info on that page, then that is a different story
Old Jul 29, 2010 | 06:51 PM
Ltngdrvr's Avatar
The rear brakes are the same whether brembo or standard, GT or GT500.
They are not dual piston calipers, they are single piston calipers. Part of this is dictated by the parking brake mechanism, it is a ratcheting system that advances the pad when applied by twisting the adjusting mechanism inside. There is no two piston calipers that work this way, only single piston.
Don't believe me? Pull the rear wheel on your brembo car or GT500 and look.
Old Jul 29, 2010 | 07:21 PM
Ltngdrvr's Avatar
Rear caliper picture, actually looks basically the same as the caliper on my '04.
Old Jul 29, 2010 | 08:29 PM
I guess Ford is gonna have to replace alot of rear calipers then!
