4.6L GT Modifications Place to discuss the 4.6L 2010 motor based modifcations.
MGW Shifter. Kind of notchy?
Old Jun 16, 2013 | 02:33 PM
10MustangGT's Avatar
Anyone else think their MGW short shifter is somewhat notchy? I have it set on 5 turns and it isn't very smooth.. I have to use a good amount of force to get it into gear. My stock shifter was smooth and incredibly easy to shift. The MGW is a lot harder... Anyone else have this or know how to fix it?
Old Jun 18, 2013 | 06:23 AM
MGW's Avatar
MGW
Former Vendor
Our shifter is not notchy. the trans is. the shorter you set the throw the notchier it will feel. thats why our shifter is adjustable because nobody has the exact same preference.
Try turning it all the way in for a mild 15 percent reduction in throw. it will feel smoother and also easier to shift.
also it will break in in about 500 miles and feel easier and smoother.
george
Old Jun 18, 2013 | 04:24 PM
I will try that! thanks!
Old Jun 25, 2013 | 04:20 PM
Sieran's Avatar
If it is anything like mine, it will get better. First few hundred miles were a little harsher than the stock shifter. After that (i have about 1,200 miles on my MGW so far) it has gotten lots better.
Not sure if the shifter for the '10 v6 is the same, but if 1st and second are bothering you make sure you have it adjusted right. It took some fine tuning of that side bolt to get them to engage correctly.
**edit**
Just looked and it is not the same... ignore what i said about 1st and 2nd.
Mr. V
Dec 24, 2016 02:57 PM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
MustangConvert11
Sep 30, 2015 08:01 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
SMOKE46
Sep 6, 2015 09:40 PM
