M6 transmission grind ??
was going thru the gears aggressively the other day and going from 4th to 5th it had a grind, would not let the shift go in, I had to come back out and go back in, this never happened before, has it to any of you ?
Yes, sometimes the clutch pedal will stick, but I usually don't get the grind. This issue can be resolved by replacing the clutch line with an aftermarket steel braided, higher volume line and changing fluid. You can do a search - clutch grind, or clutch line.
Rando
8/25/21 11:12 AM
