v1 radar install
Old Sep 23, 2010 | 02:03 PM
skullzero's Avatar
v1 radar install
ok took out my v1 from my old 08 gt and was getting ready to install it in my 2011 gt500 , on the old car spare fuse outlets were empty sockets now that i look at my fuse panel the spare sockets have a fuse installed in them, so i just pulled the fuse out installed it in the add a fuse plug then put into the socket into spare socket( #13 a 5a socket) then turned over the car , and i didnt get any power to the radar. i also left the battery hooked up , should have i disconnected the battery and then reconnect after install?? so any help would be apprciated.
Old Sep 23, 2010 | 04:35 PM
chutoyy's Avatar
The spare location is for spare fuses in case one of the usable ones are blown out.
You will have to tap into a different fuse location with the add-a-circuit to hardwire your V1.
Old Sep 23, 2010 | 05:33 PM
skullzero's Avatar
well that makes more sense. i thought aleast those were switchable / useable with power , but oh well np to put into a already dedicated socket. hey thanks i do appriciate the help and quick answer.
Old Sep 23, 2010 | 07:31 PM
skullzero's Avatar
do you have a v1 radar yourself and if so what fuse# did you use??
Old Sep 24, 2010 | 01:41 PM
skullzero's Avatar
it seems that every socket i put the add-a-circuit the v1 doesnt turn on, plus i didnt ground it while doing this ,crap this was easier in the s197 model than the 2011 gt500 . totally at a loss here.
Old Sep 24, 2010 | 11:59 PM
chutoyy's Avatar
Uhh... Try grounding it... lol.
I don't remember the fuse outlet I used, but I believe it was the windshield wipers cause it had switched power (ACC/ON)
Old Sep 25, 2010 | 09:42 AM
ScottH's Avatar
Gotta ground it. I don't have a Shelby, just a lowly GT, so I am not sure if the interior fuse block is the same, but I put my add-a-fuse tap into the slot with the body module. It only has power when the key is in the on/start position, that way the V1 does not come on in accessory or in the retained power mode when you pull the key out . Just a note, if your fuse tap has two fuse slots, be sure to put two fuses in it, otherwise the V1 will not power up. I put the fuse that came with the V1 in one slot and I took the fuse from the fuse block where I plugged my tap into and put it in the second slot.
Hope this helps.
Old Sep 25, 2010 | 11:22 PM
skullzero's Avatar
i have been using the 2011 mustang manual cause in the gt500 supplemental manual doesnt have that in it. i have not grounded it, and i didnt realize that i need to put 2 fuses in the add a fuse, cause in my 08 gt i just used a switchable slot that was just open so i bet that is the reason for no power to v1 but the slot designation still worked . well to late to mess with it now will do it in the morning ,it amazing how something so simple is a pain in the *** oh well its the only way to learn. thanks all
14Glassback
Oct 4, 2015 08:52 AM
Sep 10, 2015 12:44 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
