3.55 Gears The Best Choice for 5.0L GTs?
Depends on the dyno numbers and where they peak. Posted in another thread:
Maybe no one uses the 10% rule anymore.
Use this:
Maximum Speed = (rpm X 60) ÷ (Gear Ratio X Tire Revolutions Per Mile)
10% Rule = 10% more RPM through traps and adjust with tire size or raise the rev limiter.
If you are pulling hard through the lights - too little gear. If you are shifting at 1188 ft to 1320 ft, too much gear.
Use this:
Rando
8/25/21 11:12 AM
Evil_Capri
9/11/15 08:39 AM
9/10/15 12:44 PM
