Drag Wheel Options
Old Jan 4, 2008 | 11:39 PM
Shelby10''s Avatar
Drag Wheel Options
David I may have found an option for you.... 15'' Drag wheels that fit
http://s197forum.com/forum/showthread.php?t=3547
Summit catalog PG 253
How about these
Old Jan 4, 2008 | 11:44 PM
Shelby10''s Avatar
WOW finally someone came up with an affordable DRAG WHEEL OPTION!!!! SAAWWEEET!!
Ron on S197forum spoke to Greg personally and he assures that no spacer is needed for these and they will fit!!!
Old Jan 4, 2008 | 11:47 PM
Shelby10''s Avatar
Someone on the S197 forum asked the weight difference between this new cheaper option and the Bogarts.... WOW is all i can say..this is why bogarts are so damm expensive
Originally Posted by SixtySix
How light are the Bogarts compared with the new Weld Design Wheels?
the Weld rear weighs 16.5 and the rear Bogarts weigh 4.5 lbs...
Old Jan 5, 2008 | 07:20 AM
DavidM's Avatar
Looks promising. I can see the fronts being the ones I will get first
Old Jan 5, 2008 | 09:06 PM
2006GT's Avatar
Jarrod, How'd the bro's car turn out??
Old Jan 5, 2008 | 09:10 PM
Shelby10''s Avatar
Motor is in....tranny is bolted up....driveshaft is on...now its all the little stuff.....starter, powersteering, water pump, upper lower intake, valve covers, etc etc
Old Jan 5, 2008 | 09:18 PM
2006GT's Avatar
Maybe you and your bro should do Jeff's....
Old Jan 5, 2008 | 09:28 PM
Shelby10''s Avatar
I think Jeffs car is cursed...you told me that yourself...not touching with a 10ft pole....although his DRs worked pretty well....Jeff any updates on the motor?
Old Jan 5, 2008 | 10:13 PM
2007BadGT/CS's Avatar
What DRs did he use?
Old Jan 5, 2008 | 10:33 PM
Shelby10''s Avatar
made 3 or 4 passes...no burnouts with the BFGs that I have now.... I beleive he is now going with the MTs
Old Jan 5, 2008 | 11:11 PM
rford426's Avatar
hey buddy
Old Jan 5, 2008 | 11:16 PM
It seems that the BFGs are best for s197 and the nittos are the worst on DRs The MTs work good on my car but still spin.
Those wheels Im going to have to get
Old Jan 5, 2008 | 11:21 PM
Shelby10''s Avatar
Like David I will most likely be getting the fronts for now...rears later
Old Jan 5, 2008 | 11:27 PM
Which wheels fit our cars? Offset that is I want to order asap
Old Jan 5, 2008 | 11:38 PM
Shelby10''s Avatar
Wait a day or two so we can get a little more info on this....if you click the link on the original post you can catch up on the latest. Me and a couple of others are asking for part numbers... I believe Ron is heading this up and will give an update soon after he talks to Greg at Gregweld to confirm.
Old Jan 7, 2008 | 12:34 PM
I got the part numbers on the wheels
Old Jan 7, 2008 | 01:39 PM
DavidM's Avatar
Do tell.
Old Jan 7, 2008 | 05:15 PM
Originally Posted by DavidM
Do tell.
Which wheel? They have a race lite and a pro lite
Old Jan 7, 2008 | 05:56 PM
AndrewM's Avatar
he probably wants the prorace lite... hehe
Old Jan 8, 2008 | 07:26 AM
The 15 inch wheels are going to stick out on rear might be a problem for lowered cars drag racing. They recomend the 17 inch wheels the rears have a 7 inch BS.
