Water drainage holes in the doors - what are those plastic things?
Old Dec 10, 2006 | 05:11 AM
metroplex's Avatar
Has anyone else noticed black plastic doohickeys clipped into the drainage holes on the doors (at the very bottom towards the front and rear)?
Were these removed during PDI (are they still on your car)?
Should I remove them?
Old Dec 10, 2006 | 09:53 AM
94tbird's Avatar
pic? car is in the bodyshop and i cant go look
Old Dec 10, 2006 | 10:56 AM
metroplex's Avatar
Pic.
It doesn't look like it can be easily removed. There is a clip for the forward drain and rear drain (rear drain shown in photo) of each door.
Attached Thumbnails Water drainage holes in the doors - what are those plastic things?-door_clip.jpg
Old Dec 10, 2006 | 11:27 AM
94tbird's Avatar
weird ii never noticed them. you sure they are drain holes?
Old Dec 10, 2006 | 11:34 AM
metroplex's Avatar
On my 2000 Crown Vic, there are drain holes placed in the same exact areas as the Mustang, except with the Mustang there are plastic clips placed inside of the hole. I've also noticed water draining out of that area on the Mustang when washing the car.
I can't think of any good reasons to have the clips there other than to prevent debris from entering the drainage hole from under the vehicle. That also means debris cannot exit the drains if it falls in from the top (window channel).
Old Dec 10, 2006 | 12:43 PM
94tbird's Avatar
hmmm interesting.
Old Dec 10, 2006 | 12:54 PM
fake68's Avatar
My doors have them on the rear holes but not the front holes.....
Old Dec 10, 2006 | 03:19 PM
scramblr's Avatar
LOL, that's because they come off really easy. Didn't see a need for those clips to slow draining so I took them off.
Old Dec 10, 2006 | 03:37 PM
metroplex's Avatar
How do they come off? Did you simply tug on them? I don't want to scratch the paint.
One of mine fell out on the third day I owned the car the other one is still in place.
Old Dec 10, 2006 | 03:44 PM
scramblr's Avatar
One was so loose it practically fell in my hand. I just pulled the rest of them off. It's only little plastic tabs behind them and they pull right off.
Old Dec 10, 2006 | 03:55 PM
metroplex's Avatar
I just went out and removed all 4. They are very flexible and held in the drainage hole via clips on the sides. Simply flex them (bend them outwards) and it will come right out. I promptly waxed the hole with Klasse AIO.
Old Dec 11, 2006 | 12:39 PM
Giddyup's Avatar
Are these plastic tabs definitely supposed to be taken out?
Old Dec 11, 2006 | 01:07 PM
metroplex's Avatar
They came out very easily and I've never seen them on other cars. You want the drain holes large enough for debris to fall through. The clips would prevent stuff larger than a granule of rock salt to fall out.
Old Dec 11, 2006 | 01:14 PM
pegasusphototx's Avatar
When the car goes concourse in 20 years, you can sell those clips for big bucks on eBay!
-danny
Old Dec 11, 2006 | 02:22 PM
jacostang's Avatar
-danny
Yup!!!!
Old Dec 11, 2006 | 02:37 PM
Giddyup's Avatar
I went out and looked, and the one closest to the hinge on both sides was already gone, so I removed the other one on each side. Went down to BS with my buddy at the service dept., and he said they are supposed to be removed......
Old Dec 11, 2006 | 10:15 PM
Stoenr's Avatar
I had one in each door also. took them out right then.
That spot is usally good for a few more drips every time you wash the car and close the door.
Old Dec 11, 2006 | 10:29 PM
jacostang's Avatar
Now I have to go look at mine to see what s there!!!!
Old Dec 12, 2006 | 11:57 AM
Fastrack's Avatar
I also removed those clips the first day I had the car. I couldn't see the point in preventing the water draining..
