Unusual 0.6 amp Parasitic Draw
I have a 2005 Mustang V6 Convertible w/ Pony Package (originally had the Shaker 500 but that's been replaced). Currently when the car is off and at rest it is pulling .14 amps according to my multimeter. I had water intrusion years ago like many others (which I have since mitigated), but it got some water and corrosion on my SBJ at the time.
Steps I have taken to try to fix/diagnose this issue:
Based on my symptoms and the diagnostic attempts I listed above does anyone have a suggestion of what else I should try to either diagnose or fix this issue?
- I replaced the battery just in case it was contributing (but did not help).
- I removed all the fuses in the SBJ, but this does not change the draw.
- I replaced the SBJ box, but this did not change the draw.
- I cleaned the corroded contacts on the connector plugs to the best of my ability (but had no impact)
- There do not appear to be any shorted lights staying on in the trunk, car, or glove compartment.
- I tested the alternator (both the Red B+ line and the 3-pin connector) did not impact the draw.
- Disconnected the amplifiers to see if they were staying powered due to the corrosion but they are not.
Last edited by Indy; Dec 14, 2025 at 09:42 AM. Reason: Fixed material mistake about question.
Welcome,
It Seems The Drain Issue is Never Ending and Many Threads Have Been Done on Them and it Sounds Like You Have Covered a Lot of Bases.
Check Out This Post For Some Alternator Perspective!
https://themustangsource.com/forums/...7/#post7093111
Also For Some Chasing an Electrical Gremlin I Would Watch These Vids!
https://themustangsource.com/forums/...issues-551265/
KC
KC
welcome to the forum
The only way I know to isolate the source of a current draw, is to remove fuses one at a time, while measuring the draw, to see when the draw stops -- then you have at least narrowed it down to one circuit
So I misdiagnosed the draw's amount. The draw is actually only .14 amp (I forgot to put a screwdriver in the door latch while I was working so the vehicle was staying in awake mode).
I'm going to update my original post accordingly. With that realization:
I'm going to update my original post accordingly. With that realization:- I re-tested all the fuses while vehicle was asleep and none of them had any impact on the draw.
- I also tested the alternator diode and 3-pin connector, no issue with the alternator.
Parasitic draw - Check your starter
Hi.
This problem plagues most early S197s.
Two years ago I got fed up and restarted the pain staking process of tracing every wire, ground and components. I had swapped my radio and SJB a few years prior.
What I finally found was my starter was pulling about the same draw as you found.
I tried swapping out the wires and the same thing. I then ended up changing the starter.
So far 2 years and no issues. 🤞
I hope this helps.
I hope this helps.
I can relate. I had my 2006 for 15 years and put eight batteries in her. Some of those, at least, were replaced under warranty by the dealer. But it was a nuisance.
