Technical Service Bulletins
Old Feb 16, 2005 | 08:11 AM
r22tech's Avatar
Edit by Galaxie
This is a great idea by r22tech.
The thread has been locked and posts have been deleted so that the information is easy to find. When more TSB's surface, if this list hasn't been updated, PM a 2005 forum moderator or super-moderator and it will be updated.
TSB's are not recalls, they are considered minor problems that may occour. If you do have any of problems listed in the TSB's, the next time you are at your dealer, you point out the problem and reference the TSB number for the technician.
This does not mean that your car is a lemon. Every car has TSB's its just that the information is hard to find, rarely will you come across it. Consider this a handy reference for your 2005 Mustang.
<span style="color:green">
Special thanks to all the contributors, namley PACETTR, LLG05, packman1969, afixer and many others.</span>
Disclaimer. Do not attempt to diagnose and repair these problems yourself. Your car is under warranty, let the service department deal with it.
Old Jun 27, 2005 | 06:32 PM
Galaxie's Avatar
I Have Admin Envy
Updated September 6th 2006
Updated May 20th 2006
special thanks to forum member afixer, 05stangkc and others
04-09-06 Iron Particle & Industrial Fallout Removal
04-14-07 Service Wiring Harness Replacement
04-16-01 Engine Misfire or Rough Running
04-24-05 Rear Window Defroster Grid
04-24-14 General PCM Programming Instructions
04-24-20 Limited Slip Axle Chatter
04-26-16 Weld Bonding Procedure
05-03-01 MAF Diagnostic Service Tip
05-06-09 Intermittent CD Player Problems
05-10-19 Intermittent CD Player Concerns - Supplement to 05-06-09
05-08-06 Exhaust Vibration at 850rpm - 4.0L engine w/automatic
05-08-08 Grinding/Growling Noise in TR3650 Manual Transmissions - Vehicles Built Before 1/15/05
05-09-11 Front Suspension Popping Noise When Turning Right or Left - Vehicles Built Before 04/08/05
05-09-14 Convertible Top Raise/Lower Instructions
05-09-15 MIL and DTC Lamps on with both DTC 2106 and P135 - Vehicles Built 11/29/04 and Prior
05-09-03 Interior Plastic Trim Paint-to-Match & Repair
05-14-04 MIL and DTC Lamps on with both DTC 2106 and P135 - Vehicles Built 11/29/04 and Prior - Superceedes 05-09-15
05-09-18 Discharged Battery - Charging Service Tips
05-07-03 Rear Axle Whine - Vehicles Built Through 11/15/04
05-15-08 Ticking and/or Knocking Noise From Engine
05-15-13 Front Sidemarker Lamp Retaining Tab Breaking
05-17-14 Loose Seat Cusion Cover Trim on Front of Seat
05-18-07 Wire Splicing and Crimping Repairs - Service Tips
05-18-10 Brake Squeaking - Vehicles Built Before 3/8/2005
05-6-15 Air Bag Warning Lamp On - DTC B1891 In Restraints Control Module Or Lamp Flashes Code 53 - Vehicles Built Before 10/02/2004
[attachmentid=36114]
Updated Seat Concern
[attachmentid=36113]
Rear Axle Noise
06-04-01 Centre Stack Rattle
06-03-13 Fuel Tank Slow to Fill (for both '05 and '06)
05-04-08 Fuel Tank Slow to Fill
06-05-04 Parking Brake Freezing
06-10-13 Erratic Fuel Gauge
06-01-05 DTC P1000 May Not Clear at High Altitudes
06-02-09 DTC Trouble Codes
06-04-01 Rattle From Centre Console
06-09-113 Valve Lash Adjuster
06-10-05 Tranny Leak 5R55S
05-16-12 Harness Replacement
05-20-02 Rear Axle Noise
05-22-08 Missfire, Rough Running
05-24-06 Convertible Concern
05-21-02 Limited Slip Rear End Moan
06-12-11 Rear Axle Moan & Groan
06-09-09 Hesitation on Acceleration
06-10-01 AC Clutch 4.6
Antigini-GT/CS
Oct 5, 2015 09:43 AM
HizliBullet
Sep 27, 2015 12:52 AM
DrVet
Sep 23, 2015 01:48 PM
DrisStang
Sep 14, 2015 06:20 PM
Sep 10, 2015 08:31 AM
