Smart Junction Box Replacement
Old Apr 20, 2023 | 07:33 PM
  #41
05stangkc's Avatar
Originally Posted by Draeger355
I have been having issues with my 05 V6. Been going on for several years now. I know about the cowl drain plugs but never got into the extend of where it goes to until now, when I just took it out of storage. Started it up and no wipers. Checked all fuses was good. More I looked into issues it everything led to the SJB. Now I found a good junkyard one with all matching numbers. Installed it and still no wipers and now no HVAC. It stated and ran just fin otherwise. But looking I found a fuse in the hood fuse block for the SJB fuse. Replaced it and key fob did not work. I used the key to unlock the door and the alarm sounded. Only thing that would make it stop was disconnecting the battery. I just seen a video that the fobs need to be reprogrammed. Everything I have read so far has been SJB needs to be programmed and others have said no it doesn't (just need to find matching numbers box). So which is it?????? Lucky the car is not my daily driver so I have other vehicles to use while I get it fixed.
You Are More Likely to Have Better Luck with a Numbers Matching Used Part But It is Unlikely Programed To Match {Exactly Your Car}. See PDF'S For Shop Manual Info! I
Hope These Help!
05-06 Boxes are Different Than 07-09 Boxes!
Actual Pin Locations Of Wiring Are Different. So Same Situation If You Are Using a Using a Used Dash Wiring Harness. Went Through This With a Member Recently.
KC
File Type: pdf
File Type: pdf
elvism
Dec 9, 2010 10:34 AM
Ethanjbeau
Jul 13, 2010 01:26 PM
pony racer
Jun 8, 2010 10:16 PM
samckernan
Dec 21, 2007 07:48 PM
tekman13
Dec 3, 2004 11:05 AM
