S197 wont roll
Old Sep 26, 2025 | 12:14 PM
Trevian26's Avatar
S197 wont roll
I have a 2006 Mustang GT 5spd manual.
Few months back I had my gears swapped to the Ford Performance 3.73 kit and had a shop install it. Lately Ive noticed a whining noise coming from the rear end of the car. Its apparent in all gears at all speeds but drowns out by exhaust as I go faster. I also hear it when in neutral coasting or with clutch down also. Its easily noticeable when I am making a turn.
Recently when pulling out of a stop light and I am shifting through the gears, once I get into 3rd I noticed my rpms dying down and I hear a loud clunking noise. So I go into neutral and try to coast into a safe place. Without me braking and I am still rolling at about 5mph. The vehicle just stops, as if I slammed the brakes but I didnt.
I then couldnt push it forward or backwards while in neutral. I got it towed home and some how it wanted to roll down the bed of the tow truck. Then I started it up and eased it into the driveway.
I had to move my car a bit to pull out my generator, so I push it a bit while in neutral and maybe 4 feet later I hear a click and then it stops dead in its track again. Wont go forwards or backwards.
Heres all the information I have gotten from testing stuff out yesterday:
I can start the car in first gear with clutch down.
I can also start it in neutral clutch down.
I can also rev the car in neutral and first gear in neutral.
Idling Rpms are also good
I can move my shifter into any gear with the car off clutch in, I can also move the shifter into any gear, car started, clutch down.
I some how was able to throw it into reverse and it went back just fine but if I go into first and ease off clutch the car stalls out. It feels like it wants to go forwards but feels like its straining or something is stopping it and making it stall.
I lifted the rear end and tried rotating the wheels, both rear tires rotate same direction but takes a good amount of force compared to what I remember.
Put down rear end I then tried pushing it forwards or backwards and it rolls just fine in neutral.
I then tried with it in First gear with the clutch down and it stops in its tracks again.
Lift rear end again and now the wheels dont want to rotate
I am leaning towards differential. I think getting a new carrier and 4.10 gears should be enough to fix whatever was done. Possibly shop installed the 3.73 improperly???
Any input would be greatly appreciated.
Old Sep 26, 2025 | 12:53 PM
05stangkc's Avatar
Quote
YES!
Best Guess Without Popping Rear Cover and Inspecting!
Installing Rear End Gears Takes The Right Mechanic. 35+ Years Working at FORD Dealers in Parts and Very Seldom Did We Have More Than One Guy in The Shop Who Would Do Gears and They Usually Did Not Want To Do Them as They Were So Hard To do Correctly!
BTMO
KC
Old Sep 26, 2025 | 01:04 PM
Trevian26's Avatar
Originally Posted by 05stangkc;[url=tel:7092790
7092790[/url]]Quote
YES!
BTMO
KC
The shop that did it was local and charged me $250 for the labor of installing it. Im thinking of towing it to Jax FL and having this transmission/gear shop work on it. The guy said he charges $795 labor to work on a solid rear axle and for him to replace everything listed and the obvious LSD rebuild kit for bearings and such.
Ive read the reviews and he has 4.7/5 stars, does this seek legit and I could actually be back on the road. Just scared for another shop to f me over.
Old Sep 26, 2025 | 01:31 PM
05stangkc's Avatar
Have You Discussed Issue With Installing Shop?? Also Gears Can Get Damaged in Shipping and Have Cracks in Them. Could Be a Parts Issue. Did The Gears You Bought Have any Warranty on Them?? I Would Not Be Eating a Repair That Was a Few Months Old! At The Very Least Some Kind of Refund!
KC
Old Sep 26, 2025 | 01:55 PM
Trevian26's Avatar
Originally Posted by 05stangkc;[url=tel:7092792
7092792[/url]]Have You Discussed Issue With Installing Shop?? Also Gears Can Get Damaged in Shipping and Have Cracks in Them. Could Be a Parts Issue. Did The Gears You Bought Have any Warranty on Them?? I Would Not Be Eating a Repair That Was a Few Months Old! At The Very Least Some Kind of Refund!
KC
The installation was in early April of this year, I started hearing the noise late May early June. I stated my concerns and they brushed it off as road noise or tire cupping since I just so happened to mentioned my alignment being off too. The stang broke down beginning August. When I received the parts, I never even opened the boxes and just handed them off. I purchased the Ford Performance 3.73 gear installation kit from American Muscle so I am not sure about a warranty on them since I know I didn't purchase one.
Im okay with paying for new parts since I wanted to do 4.10 gears instead with it no longer being my daily. Realistically I can cough up the $795 labor and have all parts ordered in Jan, after holidays. I just want it up and running again and done right.
Old Sep 26, 2025 | 02:48 PM
05stangkc's Avatar
Well Being in Florida There are Ton's Of Good Shops Out There. If It Were me And I Had Not Heard Any Good Word of Mouth on a Particulary Good Rear End Shop in Your Area I Would Go To a Local Car Show & Gravitate Towards Any Modified Mustang Owner & Ask Around About Any Good Places To Go!
KC
FRPP R&P May Have Some Coverage!
Save All Old Parts & Keep Any Documentation You Have & When New Installer Puts In Gears Try & Get Documentation If He Thinks it Was a Part Failure! Would Not Hurt To See If American Muscle Can Help As Well!
The Squeeky Wheel gets The Grease as Long As In This Case it Was Part Failure Not Install Issue!
https://performanceparts.ford.com/part/M-4209-88373
Old Sep 26, 2025 | 03:10 PM
m05fastbackGT's Avatar
I went through a similar experience several years ago when taking my 2006 GT to a shop that somebody referred... After he uninstalled the previous 4:10's and reinstalled the stock 3:55 gears, I also noticed the same loud whining noises which I never encountered with the 4:10s... After numerous complaints with the shop owner, he finally agreed to reimburse me for the labor costs, but not for 3:55 gears that he ruined, by not setting them up properly....
I finally ended up having to purchase a new set of 3:55 gears and had my local Ford dealership do the reinstallation... Needless to say, after the Ford technician examined the 3:55 gears which the previous shop owner installed, he did confirm they were in fact not set up properly which resulted in causing the 3:55s to produce the loud whining noises...
By the time, it was all said and done, I ended up forking out an additional $1,500.00 for parts and labor.... At any rate, a very hard lesson learned the hard way...
Old Sep 26, 2025 | 03:26 PM
05stangkc's Avatar
One Reason I Never Went to the 3.73's My Shelby Would Love! Expensive & Hard To Find a Good Rear End Tech. Should Have Done it When I Was Still at Clevenger. It if Had Gone Bad There They Would have Made it Right! Should Have Been a Factory Option. I was already Paying I Think it Was a 3K$$$ Gas Guzzler Tax! OUCH!
KC
Old Sep 26, 2025 | 03:35 PM
Trevian26's Avatar
Originally Posted by m05fastbackGT;[url=tel:7092796
7092796[/url]]I went through a similar experience several years ago when taking my 2006 GT to a shop that somebody referred... After he uninstalled the previous 4:10's and reinstalled the stock 3:55 gears, I also noticed the same loud whining noises which I never encountered with the 4:10s... After numerous complaints with the shop owner, he finally agreed to reimburse me for the labor costs, but not for 3:55 gears that he ruined, by not setting them up properly....
I called one Ford dealership and they said they would only touch it if I am wanting the whole rear end replaced, axles included. Another dealership said they would do it at $165 an hr but it would be 15hrs of labor. And now thinking about it, that shop never gave me my stock 3.55s lol.
Old Sep 26, 2025 | 03:52 PM
05stangkc's Avatar
You Had 3.55's! That's a Great Gear! Not to Beat You Down But The Difference Between Those and The 3.73's Are Nil. Now if You Had The 3.31's To 3.73 You Would Notice. Now Going From 3.55's to 4.10's Yes You Will Notice.So Going Down Another Notch is a Good Choice at This Point! BTMO!
As Far as Dealers So Few Are Any Good These Days. That is My Experience in My Area. Of All The Dealers I Worked At Over The years only a Couple Were Worth a **** and Now That I'm Retired and My Best Dealership Being Sold Twice Since I Left There is Not One I Wouldn Feel Comfortable Doing Work on My Cars!
Crappy Deal!
On a Side Note!
I Had an 05 Gt With 3.31's, My 07 GT/CS Had 3.55's But it was Roushcharged & Did Not Need Any More Gear! For Whatever Reason The 07-09 Shelby Gt-500's Had 3.31's and With The Dual Disc Clutch Always Launch Weird. The Kr's Had 3.73's and Drove So Much Better, Weird Deal, I Have talked To Other 500 Owners & They Agree! So a 3.73 in a 500 is a Real Upgrade!
KC
Old Sep 26, 2025 | 05:44 PM
Trevian26's Avatar
Crappy Deal!
On a Side Note!
KC
I actually noticed the difference between the 3.55 and 3.73 very well. At the time my mustang was my daily and I did a majority of my driving on the interstate. But now that I have a different daily and it would be mainly rural city driving and occasional fun trips on the hwy, I am now wanting the 4.10s. I think it would go well considering I am FBO. I loved the launch of the 3.73, felt like the perfect amount without flying through gears.
Old Sep 26, 2025 | 06:00 PM
05stangkc's Avatar
Sounds Like it Was a Sweet Spot in your Case!
That's Cool!
If You Want To Calculate Rpm's With Different Gears & Tires Here is a Good Tool Thread!
https://themustangsource.com/forums/...ulator-549545/
KC
Old Sep 27, 2025 | 03:52 PM
Then I would suggest that you contact that shop and tell them you want your stock 3:55 gears back or have them credit you the cost for the 3:55's... As for upgrading to 4:10 gear ratio, I will also suggest 4:10s only if your Mustang has an Auto trans and is naturally aspirated, otherwise I would recommend no more than 3:73 gear ratio if your Mustang is a 5spd. manual (which you previously stated) for both naturally aspirated and boosted applications...
Crappy Deal!
On a Side Note!
KC
Agreed! There is very little difference between 3:55 vs 3:73 gear ratio.... Perhaps there were other mods involved when the OP upgraded from his stock 3:55 gears to the 3:73's... However, that's just a guess on my part...
The reason behind Ford/SVT's decision for the stock 3:31 gear ratio for the 07-09 Shelby GT500 was due mostly for highway driving applications and fuel economy purposes...
As for the KR's, those were not built-in house by Ford/SVT, but rather sent to Shelby American for the KR conversion upgrade package... This would explain the reason the KR's came installed with 3:73 gear ratio over the stock GT500's 3:31 gear ratio...
AOWMK
Nov 14, 2018 09:59 PM
osso12
Jan 19, 2014 10:55 PM
Chubbs88
1994-2004 V-8
Jun 5, 2012 04:33 PM
touring
Jan 27, 2008 01:13 AM
metroplex
21
Jan 8, 2007 10:34 AM
