s197
Old Nov 2, 2023 | 10:00 PM
GhostedByNyx's Avatar
Exclamation s197
hello everyone im new to this site and im hoping i can get some help. my bought my 05 gt a while back and it had a lean condition on it did a tune up and oil change on it and it went away for a while then came back replaced the coils and maf sensor the second time it came back and it was fine for a while then persisted to come back did some research and digging come to find out it jumped timing. did a timing job on it going by the ford repair manual and now it will only start and run with the maf sensor unplugged if i plug the maf sensor it wont start or run and my radiator fan wont come on either. has anyone else had this issue and found a solution if so please share
Old Nov 2, 2023 | 10:30 PM
m05fastbackGT's Avatar
Hello and welcome aboard! After reading over the troubleshooting steps you've taken, does your "05" GT have an aftermarket tune and also an off-road exhaust setup? If the answer is yes to either one or both, you may also need to determine if any of your 02 sensors are malfunctioning... If neither applies, you may want to consider checking for vacuum leaks which can also cause a lean condition... Knowing that your car will only start when the MAF sensor is not plugged in, I would suspect and make certain as to whether your MAF sensor is defective or not... The best way to troubleshoot outside of taking your car in for servicing is by connecting a hand-held scanning device tool to your vehicle's OBD II port which will scan your car's ECM for any potential trouble codes... Therefore, I would start there if neither of the troubleshooting steps I suggested, applies here... Meanwhile, let us know if any of the info provided is helpful in any way...
Old Nov 2, 2023 | 11:52 PM
o2 sensors are fine and the maf sensor is new after doing the timing while following the ford repair manual the lean condition is gone just wont run with the maf sensor plugged in and my radiator fan doesnt kick on when needed
Old Nov 3, 2023 | 02:19 PM
So, if the car will not run while the MAF sensor is installed, but will run when not installed? this leads back to the MAF sensor... Just because you purchased it new, doesn't necessarily mean that it isn't defective... As mentioned before, the best effective way to find out for certain is by connecting a hand-held scanning device to your vehicle's OBD II port for potential trouble codes... Once you see the codes, you will find out exactly what components are causing your lean condition issues by entering the codes on Google!
Old Nov 3, 2023 | 02:40 PM
05stangkc's Avatar
While You Were Out Rocky I Put Out The Obd Codes For Pretty Much all Models! Look For Sticky's In Repair Sections.
https://themustangsource.com/forums/...e-info-550470/
And I Mean All Codes!
What Fun that Was!
Lots of Diagnostic Stuff Too!
Kc
__________________
Old Nov 3, 2023 | 04:34 PM
There are no codes after the timing job besides **** for my cluster and my tail lights
Old Nov 3, 2023 | 06:34 PM
05stangkc's Avatar
@Sn9582
This New Member is a Ford Tech! Maybe He Has Run Into This!
KC
Old Nov 4, 2023 | 03:15 PM
What Fun that Was!
Kc
__________________
Good stuff indeed, Kevin! The code lists will provide very helpful resources when it comes to troubleshooting potential problem issues.
Then as mentioned below, I would also consider contacting our newest forum member @Sn9582 as he is a Ford technician!
@Sn9582
KC
Good advice indeed, Kevin!
LK06
Aug 25, 2022 05:38 PM
Racercook315
Jun 28, 2021 09:35 AM
Vader99
1994-2004 V-8
19
May 21, 2020 10:34 PM
ZackariJones327
1994-2004 V-8
Sep 25, 2016 09:04 AM
azoufan
Jun 16, 2015 02:18 PM
