Rear Differential & Manual Transmission oils for 08 4.6 GT
Old Jun 5, 2016 | 07:17 PM
cardwiz428's Avatar
Guys, Book says for rear diff oil Motorcraft SAE 75W-140 and for manual transmission oil Motorracft Mercon V ATF oil. My question is how hard and fast on only using Motorcraft oils. Has anyone used a sub (Redline, royal purple, etc) and had any issues or gained better results. Getting ready to change mine and want opinions..
Old Jun 14, 2016 | 07:41 PM
cardwiz428's Avatar
Update: I went with Redline for both trans and rear diff...seems to shift easier..
Old Jul 21, 2016 | 01:00 PM
inspecto's Avatar
I went with Mobil 1 syn ATF for tranny not much different than what came out of it, did not look to bad 55000 miles.
Old Jul 22, 2016 | 06:23 AM
Gabe's Avatar
I tend to use Amsoil whenever possible.
Just did a rear-diff fluid change on the fiancee's Shelby.
It got Amsoil 75-140 fluid, and both of these, trying to quiet down a dull whine during slow turns.
It worked! She's quiet now!
Old Oct 14, 2024 | 06:41 AM
Jeff T's Avatar
Too much friction modifier?
Finally got around to changing mine. I bought this
Amazon Amazon
I used 2 of these plus the 4oz ford friction modifier. After getting it all in, I saw in small print on the oil bags that they already contain friction modifier. So do I have too much modifier?
Old Oct 14, 2024 | 10:43 AM
05stangkc's Avatar
Won't Hurt a Thing!
I Don't Know if They Are The Same as Back in The Day But That Vintage FORD Stuff Smelled Like a Dead Dinosaur!
KC
Old Oct 14, 2024 | 01:03 PM
Jeff T's Avatar
Won't Hurt a Thing!
KC
Thanks. Yes, it stinks really bad. Worse than dinosaur dung.
Old Oct 14, 2024 | 01:39 PM
Bert's Avatar
yeah I think you will be OK .... if you find that you are getting "one wheel peel" then it might be too much friction modifier
Old Oct 17, 2024 | 01:40 PM
rocknrod's Avatar
Clean Machine Supercharged S-197 Member
Originally Posted by Jeff T
Finally got around to changing mine. I bought this https://www.amazon.com/gp/aw/d/B08KB...?ie=UTF8&psc=1
I used that same stuff. I talked to Valvoline about it and they said do not use friction additive with this particular blend.
dancorneliu79@yahoo.com
Sep 1, 2016 02:48 AM
BOSS302R
Jun 14, 2012 07:14 PM
nickt916
Apr 28, 2012 09:54 AM
Zoldier
2012-2013 BOSS 302
Oct 3, 2011 10:41 AM
johney5
22
Nov 29, 2006 05:07 PM
