Rattle fixed
+1 on HL22's fix. I used a metal and rubber washer as pictured above and it worked perfectly!
Did your noise go away when the car warmed up? My friends are telling me maybe a throw out bearing
Ford is fixing the noise under the power train warranty.
Picking up my ride now
Mine only does this on a cold start up.. it lasts maybe 2-3 seconds, when the idle first rolls down to normal.. Annoying as all hell.
I hope this fixes it. Thanks, ~j |
That noise is gone from the transmission at start up. I'm happy with the repair that the dealer did. Thank goodness the it was covered by my power train warranty nothing out of pocket
Originally Posted by Always broke
(Post 6043344)
I have a stick they removed my trans and replaced the thin scatter shield
(Post 6052735)
I have what is a constant sound that I get from my 07 when I start the car if it is cold (+6 hours). It sounds almost like a grinding noise but goes away after about 5 min of running. It is not associated with any RPM. Is that what you were hearing from your car? |
Same thing my cousin has an 05 GT and out makes the same sound
Used a stainless and rubber washer on each of the two bottom bolts today and problem solved!!!! Such a relief!
