new window motor not working, power to plug
on another issue does anyone have a diagram showing the convertible top side hydraulic shocks showing where on the frame it connects as I got the bolts to reattach them but all the way extended they are not long enough to reach the frame so is there a part missing that I need
Item 2 in Exploded View!
https://themustangsource.com/forums/...2/#post7079510
KC
This is The Kind of Parts Picture That Would Drive Us Crazy in The Parts Department!
https://www.fordpartsgiant.com/parts...650668-aa.html
Here is a Better One!
https://www.fordpartsgiant.com/parts...7650668-a.html
Part Fits 2005-2014
Here Are Two on Ebay From Same Supplier! I Would Jump on Them!
https://www.ebay.com/itm/38720860071...8AAOSwUc9mmTmi
https://www.ebay.com/itm/38720860261...cAAOSwUEpmmTjr
Top information
I have both problems as when we first got the car the windows all worked but the top did not as the original owners disconnected the side shocks from the frame and made it a manual top so I tested the top motor behind the rear seat and it was bad so I replaced the motor and now when you put 12 volts to it the motor works but I am not getting any power to it from the switch so I replaced the switch and still no power and after testing there is no power coming to the switch yet all the fuses are good plus the relays are good so I don’t know what else to do except try to put another switch in the wire going to the motor and mount the switch up front next to the driver but don’t know if that will work without relays in the system. The other problem was the right rear power window motor stopped working so I replaced it and still not working so after some testing it appears that it lost constant power to the brown wire so I used a jumper wire to another brown wire with a blue stripe that is only hot with the key on and connected it to the brown wire and when I hit the button on the driver door to test the motor the window went down only than all the rest of the windows were dead and would not work plus the stereo went dead. Why the stereo was connected to the same circuit as the windows is confusing as I thought it should be on a separate circuit so I ran a new power wire from the battery to both brown wires on that same right rear motor and now everything works except now the radio is always on so I am really confused as what to do so PLEASE HELP ME
Power top
update as I was able to find a video showing where the brackets go but now I need to know if I can operate the power top motor with just a momentary switch hooked to 12 volts without a relay so can anyone help
Need wiring diagram
does anyone have a wiring diagram of the ignition switch on a 05 thanks
Wiring problems
update on my wiring issue as I previously stated that I lost all the accessory power when trying to use a jumper wire on the back window well I replaced the ignition switch and it’s fixed so I also ran a new wire from a new double sided switch with a ground to the power top motor and it works like it’s supposed to so if you have a problem with all the safety systems like the up and down relays on the top just run a new wire with a fuse and it works
89FivePointOhLX
Mar 1, 2012 09:56 AM
