NEED ECM / problems with my 2007 gt500
Old Aug 27, 2022 | 10:36 PM
Ankomus's Avatar
Hello, I wanted to ask you for help. I have a 2007 Shelby GT 500 with problems in the PCM/ECU, which is not working. Cylinder number 2. I sent my computer to FS1. Apparently it is without repair. and I want to know if you help me get one for my Shelby 7R3A - 12A650- AFF my name is Anko
Old Aug 27, 2022 | 10:53 PM
05stangkc's Avatar
Modified your Title to Categorize Forum Better! On a Side Note I own a 07 Gt-500 Myself.
The Id# Is the Sticker Number on the ECM it References the Actual FORD Part Number Used to Sell the Part. It also May Have Calibration Number Listed Which Would Look Similar to This If Needed
  • 7ZF2SC0508 (NBU5)
That is Great you Posted the ID# of the ECM!
Here are some the ACTUAL FORD PART NUMBER Interchanges as Well.
7R3Z12A650AFFRM
Supersession(s): 7R3Z-12A650-AFF; 7R3Z-12A650-AFFRM; 7R3Z12A650AFF; 7U7Z-12A650-FBA; 7U7Z12A650FBA
Also See Cardone /Rockauto Page for More Interchange.
https://www.autoecmstore.com/products/7r3a-12a650-aff
This is a Company I used when I could No Longer Get an Ecm From Ford.
LINK ABOVE
I checked and it is Discontinued from Ford.
LINK BELOW
https://www.fordpartsgiant.com/parts...&filter=(33897)
Rock Auto A1 Cardone Has A Listing as Well Shows out of Stock. Good Reference. They Have A notify when Available Feature.
LINK BELOW
https://www.rockauto.com/en/moreinfo.php?pk=3131400
Be Advised your PATS KEYS will need to be Programmed to Your Car if PCM Supplier Does not Sell with Keys. A Ford Dealer or High Level Locksmith will Likely Have to Do it. Verify this with your ECM Supplier.
Summit Racing Lists the Cardone But Not available until October. Heck of a Lot Cheaper Though!
LINK BELOW
https://www.summitracing.com/search/...DONE%20782149F
Please Double Check any Parts before Purchasing and Ask Questions from Sellers as Needed!
Good Luck!
Welcome to The Mustang Source!
KC
TMSBrad
2007-2009 Shelby GT500
12
Jun 11, 2008 04:57 PM
Auburnman
Jan 8, 2006 08:53 AM
iviustang50h
Aftermarket 2005+ Mustangs
Mar 22, 2005 05:59 PM
