Mustang shuts off constantly!!! Need help plz
Old Jul 16, 2011 | 05:16 PM
Jpstang06's Avatar
I have a 2006 mustang 4.0L automatic with 60,543 miles. I recently had 2 replace the whole gas pedal assembly due 2 a bad tps and now it's dying while driving down the road and on park. There is no check engine lights or any lights on at all i also replaced the crankshaft position sensor and the fuel filter same crap! Can someone plz help me we this issue I'm clueless.
Old Jul 16, 2011 | 05:42 PM
fastfordstang's Avatar
Bad gas up grade.
Old Jul 16, 2011 | 07:51 PM
Jpstang06's Avatar
Already running 93 in her it's got me stumped
Old Jul 17, 2011 | 10:27 PM
Lime GT's Avatar
I guess you could unplug the connector(s) to the part you changed and check for bent or loose in connector pins. Did you disconnect the battery while or after changing out the throttle so the KAM will be reset?
Old Jul 18, 2011 | 05:19 PM
Jpstang06's Avatar
The battery was disconnected during all procedures tried a new fuel filter yest made it run worse actually ugh. So I searched the net n I'm not the only 06 owner with this problem. After reading a few several had mentioned the throttle body gunning up so I pulled it off cleaned it real good and today no stalling out n idles good so I'm hoping like hell that's what it was.
Old Jul 19, 2011 | 07:25 PM
Darth Stang's Avatar
Also check to see the battery cables haven't come loose
SMBJoshy
Aug 24, 2015 10:55 AM
Jul 20, 2015 06:26 AM
Rodsmustang
Which is Better
Jul 14, 2015 02:09 PM
