Metal Shaking at 2500-3500 RPM???
Old Aug 15, 2008 | 09:52 AM
MBK's Avatar
MBK
hello,
in 1st or 2nd, during modest acceleration, i can hear what sounds to me like metal vibrating quickly coming from the exhaust at approximately 2500-3500 RPM... it doesn't sound normal to me. i was wondering if anyone knew what this was or have heard it? it happens less as the car warms up, or so it seems to me...
Old Aug 15, 2008 | 09:06 PM
bullitt 736's Avatar
Check your shields on the converters.
Old Aug 18, 2008 | 10:10 AM
MBK's Avatar
MBK
you might be right ill check it out thanks
Old Aug 18, 2008 | 10:29 AM
frdtch05gt's Avatar
That's exactly the same noise I have, usually happens right around 3k or so, more so when the motor is cold. I'm still trying to track it down.
Old Aug 25, 2008 | 05:12 AM
Lime GT's Avatar
Some 05's came with '2 bolts missing'
from the bottom of the trans to engine separator shield.
Old Aug 27, 2008 | 08:43 AM
frdtch05gt's Avatar
I know for sure my '06 has those bolts, I checked that first. I might be putting headers on over the winter so I will see if the problem goes away after doing that.
Old Sep 15, 2008 | 09:53 AM
frdtch05gt's Avatar
One thing I just thought of, my problem didn't start until I changed the mufflers. I probably just need to re-fit the exhaust a little bit and it will be ok.
Old Sep 15, 2008 | 11:18 AM
MTAS's Avatar
You need to put a small rubber washer/bushing between the plate and bell housing (I also put a metal washer with the rubber one to give more space):
Old Sep 16, 2008 | 07:35 AM
Etnix's Avatar
FYI there is a exhaust TSB for this also.. just take it in if it is under warranty.
Old Sep 16, 2008 | 09:13 AM
highvolts's Avatar
I had the exact same problem. However, I used a little bit of silicone RTV instead of rubber washers.
There are some other posts around that talk about this rattle. Mine also showed up after I changed the axle-backs.
Old Sep 16, 2008 | 02:27 PM
shwaco1967's Avatar
I haven't done anything to mine (exhaust wise) and it's still rattles.
Old Sep 16, 2008 | 02:38 PM
WaltM's Avatar
I had a "sympathetic" vibration that was real annoying, the TSB took care of it; made a huge difference.
Get the TSB done. You'll notice an improvement.
Old Sep 19, 2008 | 10:47 PM
frdtch05gt's Avatar
Hmm, I may have to get under my car and work with it a bit tomorrow.
Old Sep 20, 2008 | 07:09 AM
WaltM's Avatar
Here's the TSB. Sorry I didn't post it sooner...
http://forums.bradbarnett.net/attach...0&d=1203296335
Old Sep 20, 2008 | 05:44 PM
frdtch05gt's Avatar
I picked up some rubber washers from Home Depot today and put them in place on those two lower bolts, noise is gone!!! Thank you very much for that idea MTAS!
I already removed the rubber and metal hangers from the h-pipe in an attempt to get rid of the noise, but it appears the noise I had was from the engine spacer plate. I wasn't going to pull the trans just to fix that, the rubber washers will do just fine.
Old Sep 22, 2008 | 10:29 AM
MTAS's Avatar
Thumbs up
No sweat man, that's what TMS is all about
Old Oct 13, 2008 | 12:44 PM
Fords4Ever's Avatar
Originally Posted by MBK
hello,
I have just stared noticing the same thing but I thought it sounded like a quiet popping and I was afraid it was pinging or detonantion. It happens exactly as you say though on my 1-2 or 2-3 shifts under moderate acceleration. I think it goes away when it's warmed up.
If it were detonation wouldn't I hear it when I get closer to redline as well?
Rando
Aug 25, 2021 11:12 AM
Glenn
73
Apr 26, 2016 12:22 PM
Fastnloud
Feb 15, 2016 05:21 PM
robjh22
Dec 14, 2015 08:41 AM
